查看: 582|回复: 0
“傲世动力座驾” Honda civic气动避震低姿态风格改装
发表于 2020-12-5 13:40:08 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
"Aoshi power car" Honda Civic pneumatic shock absorber low attitude style modification
Honda Civic has launched a variety of models to cater to the tastes of consumers in different countries, including three hatchback hatchback hatchback coupe, hybrid and five door RV. The Honda Civic and Dongfeng Honda's existing models, Honda CR-V, come from the same production platform. The two models use the same chassis, which provides technical preconditions for the domestic Honda Civic. After 40 years of experience and continuous evolution in 10 generations of deduction, today's 10th generation Civic (Civic) gathers many advanced technologies of leading times, presenting you with a charming work with a sense of future and science and technology.
汽车改装属于汽车后市场的一种产物,许多车型因为原厂的设计比较平庸,不能满足玩家的要求,因此就出现了改装行业的繁荣现象,气动避震悬挂的改装属于一种外观的姿态改装,以贴地的美感博的玩家们的好感,视觉的强烈冲击和反常规状态引起强烈的共鸣,一起来欣赏 本田思域 改装气动避震悬挂的魅力
Car refitting is a product of the automotive aftermarket. Many models can't meet the requirements of the players because of the mediocre design of the original factory. Therefore, the refitting of the pneumatic shock absorber suspension is a kind of appearance posture modification, which causes strong resonance with the good feeling of the players close to the ground, strong visual impact and unconventional state, Enjoy the charm of Honda Civic modified pneumatic suspension
