查看: 641|回复: 0
“个性的男性用车”长城酷熊改装气动避震演绎完美低姿态
发表于 2020-11-30 16:14:34 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
"Personalized men's car" Great Wall kuxiong refitted pneumatic shock absorber to show perfect low posture
长城“酷熊”COOLBEAR,其外型一反盛行的流线型轿车外形,是中国第一款最具时尚个性的小排量男人车。长城“酷熊”COOLBEAR,其外型一反盛行的流线型轿车外形,是中国第一款最具时尚个性的小排量男人车。外观独具男人魅力,使男人开小排量轿车,不再显得平庸。
The cool bear of the Great Wall is the first small displacement man's car with the most fashionable personality in China. The cool bear of the Great Wall is the first small displacement man's car with the most fashionable personality in China. The appearance of unique man charm, so that men drive small displacement cars, no longer appear mediocre.
作为长城酷熊改装HF风格气动避震,长城酷熊改装气动避震醉美姿态 长城酷熊改装气动避震推出的第三款轿车,酷熊并没有追随精灵、炫丽的流畅风格,而选择了直棱直角、宽大方正的超主流外观。而是采用的是上海AIRBFT气动避震运营中心生产的酷熊专用双层气囊,具有完美的操控和舒适性,打造一个属于你的个性人生姿态,独特,完美。
As the Great Wall Cool Bear refits HF style pneumatic shock absorbers, Great Wall Cool Bear refits pneumatic shock absorbers. The third car launched by Great Wall Cool Bear refitting pneumatic shock absorbers, cool bear does not follow the spirit and gorgeous smooth style, but chooses the super mainstream appearance of straight edges and right angles, wide and square. Instead, it adopts the special double-layer air bag produced by Shanghai airbft pneumatic shock absorber operation center. It has perfect control and comfort, and creates a unique and perfect life posture belonging to you.
Let's talk about the pneumatic shock absorber control system. The mainstream control systems are generally divided into two types: those with memory mode and those without memory mode. Those with memory mode have to mention the control system of airbft in the United States. It should be the first system to enter China. Its stability and convenience of use are trusted and liked by many riders! Let's talk about its function and intelligence!
