查看: 599|回复: 0
'精品中高级轿车'斯柯达速派改装AIRBFT气动避震享受低姿态乐趣
发表于 2020-11-30 16:03:19 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
'boutique medium and high-end sedan' Skoda Speedo refitting airbft pneumatic shock absorber to enjoy low attitude fun
斯柯达速派,是上汽大众斯柯达全新推出的B级三厢轿车 作为斯柯达品牌“精品中高级轿车”,速派集人性科技、灵动设计、精湛工艺于一身,为用户带来高品质的驾乘之选
Skoda Speedo is a brand-new B-class three compartment sedan launched by SAIC Volkswagen Skoda. As a "high-quality medium and high-grade sedan" of Skoda brand, speedpad integrates human science and technology, flexible design and exquisite craftsmanship to bring high-quality driving and riding choices for users
斯柯达速派气动避震升级空气避震悬挂采用的是台湾 空气避震系统,具有三段记忆和四轮独立功能,目前是世界上最顶级的避震系统,质量稳定,做工完美,低趴灵魂的缔造者,深受广大趴迷的痴爱。
Skoda air suspension adopts Taiwan air shock absorber system, which has three segments of memory and four wheels independent function. At present, it is the world's top shock absorber system with stable quality, perfect workmanship, and the founder of low lying soul. It is deeply loved by fans.
