查看: 750|回复: 0
黑武士奔驰W205 C63低趴风格改装AIRBFT气动避震
发表于 2020-11-30 14:47:48 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Heisamurai Benz w205 C63 low lying style modified airbft pneumatic shock absorber
绅士若想在各类聚会中引人注目,没有独特的装饰是无法给人惊喜的。对于C级轿车的车主来说,仅仅将C级作为代步工具的话只会显得自己的生活淡而无味,追求个性,享受驾车的愉悦才是奔驰C应有的生活态度。
If a gentleman wants to stand out in all kinds of parties, he can't surprise people without unique decorations. For car owners of C-class cars, if they only use C-class as a vehicle, their life will be dull. Pursuing individuality and enjoying the pleasure of driving are the proper life attitude of Benz C.
追寻自己心中的梦想,像见到自己喜欢心仪的姑娘一样,按捺不住那份冲动,HF风格气动避震也是一样,趴下的刹那间是那么美,心里的那股冲动,像打喷嚏一样控制不了!太多的气动避震痴迷者只是对藏轮,卡边,平齐感兴趣,但是后备箱造型的硬管链接也是一门艺术!艺术的真谛就是品味,执着,永恒,智慧,心血....懂它,爱它..敬我们那份改装精神
To pursue the dream in my heart, I can't help but feel the impulse like seeing the girl I like. So is HF style pneumatic shock absorber. The moment when I lie down is so beautiful. I can't control the impulse in my heart like sneezing! Too many pneumatic shock absorbers are only interested in hidden wheel, hemming and leveling, but the hard tube link of trunk modeling is also an art! The essence of art is taste, persistence, eternity, wisdom, painstaking effort... Understand it, love it, respect our refitting spirit
正所谓一低遮百丑
这几年HF改装火遍大街小巷
气动减震
也是一夜变身改装界网红
Pneumatic shock absorption
话说这是个什么东西呢?它其实是一套可以控制气压改变车身高低的装置,与传说中的主动车身控制系统(ABC)类似不过它的工作介质是气体,一般来说就是下图所示的这么一套家伙事,其中包括弹性橡胶气囊减震器气压控制系统、后备箱储气罐及电子控制系统等它其实和空气减震的原理与常见减震器,螺旋弹簧+减震筒形式原理十分类似,只不过,通过改变气室体积(上下方向)来调整车身离地距离并一定程度改变软硬特性,另外减震筒部分则可以由电机改变通气孔尺寸,从而调节减震器的衰减力,因此空气减震器往往能提供更好的性能表现嗯!就是这么自信!
So what is this? In fact, it is a device that can control the air pressure to change the height of the car. It is similar to the legendary active body control system (ABC), but its working medium is gas. Generally speaking, it is such a set of things as shown in the figure below, It includes the air pressure control system of the elastic rubber airbag shock absorber, the air storage tank of the trunk and the electronic control system. In fact, the principle of the air shock absorption is very similar to that of the common shock absorber, the spiral spring + shock absorber. However, the distance between the body and the ground can be adjusted by changing the volume of the air chamber (up and down), and the soft and hard characteristics can be changed to a certain extent, In addition, the size of the air vent can be changed by the motor to adjust the damping force of the shock absorber. Therefore, the air shock absorber can often provide better performance! So confident!
