查看: 699|回复: 0
奥迪A4B9 KW-V3定制AIRBFT气囊专车专用后拉杆
发表于 2020-11-30 14:17:42 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Audi a4b9 kw-v3 customized airbft special rear tie rod
新一代Audi A4b9将技术和美学成功地结合在一起,令人惊叹不已。该车所有技术都是新开发的,因此也就再次为本级别车树立了标杆。今天我们来欣赏的是奥迪A4B9在国内的首台气动改装案例,安装的是台湾绞牙避震空气悬挂系统,技术的革新,科技的前沿!低趴灵魂艺术的升级!
The new generation of Audi a4b9 combines technology and aesthetics with amazing success. All technologies of the car are newly developed, so it sets a benchmark for this class of cars again. Today, we are here to enjoy the first pneumatic refitting case of Audi a4b9 in China. It is equipped with the air suspension system of Taiwan's hinge teeth suspension system. It is a technological innovation and a cutting edge of science and technology! Low lying Soul Art upgrade!
