查看: 596|回复: 0
新款GL8升级AIRBFT气动避震,提升舒适和通过性
发表于 2020-11-29 16:12:04 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
New GL8 upgrade airbft pneumatic shock absorbers for comfort and Trafficability
别克GL8自1999年面世至今,历经五代革新,已赢得超过120万用户的青睐。2020年  ,别克GL8家族先后推出全新一代别克GL8 Avenir艾维亚家族、GL8 ES陆尊及GL8陆上公务舱三大系列  ,为用户带来更多样化的选择。
Buick GL8 was launched in 1999, after five generations of innovation, it has won the favor of more than 1.2 million users. In 2020, Buick GL8 family has launched three series of new generation Buick GL8 Avenir Avia family, GL8 es land Zun and GL8 land business class, bringing users more diversified choices.
喜欢玩改装避震系统的发烧友,空气避震是话题里面最贵的一款。
听起来非常方便,气动避震到底是什么原理呢?
