查看: 883|回复: 0
“最美的E级”奔驰W211改装气压避震 经典与低姿态的完美结合
发表于 2020-11-29 14:51:51 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
"The most beautiful E-class" Mercedes Benz W211 refits the perfect combination of classic pneumatic shock absorber and low attitude
问世于2002年的第七代奔驰 (W211)延续了前一代的“四眼”风格前脸,整车的线条更为舒展、流畅,细节的处理也更圆润,大号的进气格栅增加了它的视觉冲击力。这一代 的外形尺寸比以往的任何一代都大,带给人们空前宽敞的驾乘空间。
The seventh generation Mercedes Benz (W211), which was launched in 2002, continues the "four eyes" style of the previous generation. The lines of the whole vehicle are more extended and smooth, and the details are more mellow. The large air intake grille increases its visual impact. This generation is more spacious than ever before.
今天介绍的这台奔驰在气压避震改装HF风格的感染下醉美的姿态!白色的车身外观! 贴地飞行行的姿态真的是醉了!这个低姿态也是不少人追捧的风格了。
Today's introduction of this Mercedes Benz in the air pressure shock absorber refit HF style under the influence of Drunken Beauty! White exterior! Flying close to the ground is really drunk! This low attitude is also the style pursued by many people.
在改装避震器主要选择分三种,分别是竞技短弹簧,套装,绞牙。这几种功能不同,价格也相差不少。选择适最适合自己的一款避震才是最重要的。那到底什么是适合自己的避震器呢?更换改装避震器后,首先要承担的就是舒适度损失,所以如果你还是对车辆舒适性比较追求的话那么在这里小编建议你还是不要更换的好,如果稍微损失一些没有什么问题的话,更换套装不仅可以提高车辆的操控性而且不会损失过多的舒适性。因为套装的出现,就是为在原车避震器的大结构上提高车辆的操控性能。不过避震套装也有许多不足,第一,售价略贵、第二,阻尼以及高低不可调整,第三,目前避震套装的选择,主要品牌还都集中在欧系车中,日系车套装并不热门。不过可能对许多资深玩家来说,避震套装已经完全不能够达到他们的需求,那么绞牙避震就成了他们的首选。绞牙这个词其实来源于中国的香港,其真正全称为Height. Adjustable. Damper有可调避震器阻尼段数以及车身高度的含义。看到这个名称我想我也没必要过多介绍它的功能了,全在名字里体现了。不过小编还是要插一句,更换绞牙避震后虽然可以得到理想的车身高度以及操控性能,但是却建立在损失百分之60的舒适上,所以更换前最好做好心理准备。
There are three main choices in refitting shock absorbers, which are competitive short spring, suit and twisted teeth. These functions are different and the prices are quite different. The most important thing is to choose the best one for yourself. So what is the right shock absorber for you? After replacing and refitting the shock absorber, the first thing to bear is the loss of comfort. Therefore, if you still pursue the comfort of the vehicle, then I suggest you don't replace it here. If there is no problem with a little loss, the replacement package can not only improve the handling of the vehicle, but also avoid losing too much comfort. Because the appearance of the suit is to improve the handling performance of the vehicle on the large structure of the original shock absorber. However, there are also many deficiencies in shock absorbers. First, the price is a little expensive. Second, damping and height can not be adjusted. Third, at present, the main brands of shock absorbers are still concentrated in European cars. Japanese car suits are not popular. However, for many senior players, the shock suit has not been able to meet their needs, so the first choice for them is to hang teeth. Actually, the word "twisted teeth" comes from Hong Kong, China. Its real full name is height. Adjustable. Damper, which means the number of damping segments of adjustable shock absorbers and body height. Seeing this name, I don't think I need to introduce its functions too much. It's all reflected in the name. However, Xiaobian has to add that although the ideal body height and handling performance can be obtained after replacing the hinge suspension, it is based on the loss of 60% of the comfort, so it is best to be psychologically prepared before replacement.
