查看: 778|回复: 0
玩车只看姿态 宝马E46改装气动避震经典依然存在
发表于 2020-11-28 15:38:32 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
The classic aerodynamic shock absorber of BMW E46 refitting still exists
改装是一种文化,玩车确是一种心态,心态好的人玩车姿态不会差,不管什么样的车,不改装始终只能平凡。 汽车改装属于汽车后市场的一种产物,许多车型因为原厂的设计比较平庸,不能满足玩家的要求,因此就出现了改装行业的繁荣现象,气动避震悬挂的改装属于一种外观的姿态改装,以贴地的美感博的玩家们的好感,视觉的强烈冲击和反常规状态引起强烈的共鸣, 宝马E46改装气动避震悬挂,经过十几年的时间依然风采依旧,经典不悔。
Refitting is a kind of culture. Playing with cars is indeed a kind of mentality. People with good mentality will not be bad at playing with cars. No matter what kind of cars are, they can only be ordinary without refitting. Car refitting is a product of the automotive aftermarket. Many models can't meet the requirements of the players because of the mediocre design of the original factory. Therefore, the refitting of the pneumatic shock absorber suspension is a kind of appearance posture modification, which causes strong resonance with the good feeling of the players close to the ground, strong visual impact and unconventional state, BMW E46 refitted pneumatic shock suspension, after more than ten years of time still elegant, classic no regret.
