查看: 683|回复: 0
单身贵族的专属车雷克萨斯气动避震悬挂低姿态风格改装
发表于 2020-11-27 16:14:31 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Exclusive car of single noble Lexus pneumatic shock absorber suspension low attitude style modification
雷克萨斯(英语:Lexus,日语:レクサス)创立于1983年,是日本丰田集团旗下全球著名豪华汽车品牌。该品牌仅用了十几年的时间,销量在北美地区便超过了奔驰、宝马。1999年起,雷克萨斯品牌连续11年位居美国豪华汽车销量第一的宝座。
2005年,雷克萨斯成功打入日本本土市场,也因此成为在全球均有销售的高级轿车品牌。初时雷克萨斯在美国国内以“热切追求完美”(The Passionate Pursuit of Perfection)作为宣传口号,后来以“追求完美”(The Pursuit of Perfection)作为在全球国家和地区的行销格言,直到2013年,其宣传口号改为Amazing in Motion。
In the year 1983, it was the world's largest Australia patriot. It is about 10 years old, and the amount of the article is very beautiful. In 1999, it was the first treasure troop of the first day of the year.
In 2005, it was a success to win the success of the mainland city. In the first time, we have been working on the pursuit of perfection, and the pursuit of perfection.
汽车改装属于汽车后市场的一种产物,许多车型因为原厂的设计比较平庸,不能满足玩家的要求,因此就出现了改装行业的繁荣现象,气动避震悬挂的改装属于一种外观的姿态改装,以贴地的美感博的玩家们的好感,视觉的强烈冲击和反常规状态引起强烈的共鸣,一起来欣赏雷克萨斯改装AIRBFT气动避震悬挂低趴案例!
Car refitting is a product of the automotive aftermarket. Many models can't meet the requirements of the players because of the mediocre design of the original factory. Therefore, the refitting of the pneumatic shock absorber suspension is a kind of appearance posture modification, which causes strong resonance with the good feeling of the players close to the ground, strong visual impact and unconventional state, Let's enjoy the case of Lexus refitting airbft pneumatic shock absorber suspension!
正所谓一低遮百丑
这几年HF改装火遍大街小巷
气动减震
也是一夜变身改装界网红
话说这是个什么东西呢?
它其实是一套可以控制气压
改变车身高低的装置
与传说中的主动车身控制系统(ABC)类似
不过它的工作介质是气体
一般来说就是下图所示的这么一套家伙事
其中包括弹性橡胶气囊减震器
气压控制系统、后备箱储气罐
及电子控制系统等
它其实和空气减震的原理与常见减震器
螺旋弹簧+减震筒形式
原理十分类似
只不过
通过改变气室体积(上下方向)
来调整车身离地距离并一定程度改变软硬特性
另外减震筒部分则可以由电机改变通气孔尺寸
从而调节减震器的衰减力
因此空气减震器往往
能提供更好的性能表现
嗯!就是这么自信
Pneumatic shock absorption
So what is this?
But its working medium is gas
And electronic control system
The principle is very similar
It's just
Yeah! So confident
