查看: 656|回复: 0
丰田锐志改装气动避震 要的就是这种低趴范
发表于 2020-11-27 15:16:46 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Toyoda is determined to refit pneumatic shock absorbers to this kind of low lying fan
锐志(REIZ)是日本丰田MARK X车型国产后的名称,它于2005年10月在天津一汽丰田二厂与皇冠共线生产、共用底盘,配备与皇冠相同的六速手自一体变速器。
MARK X则是MARK II 的后续车型,它采用前置后驱设计,在丰田所有车型中销量排第三位,在定位上仅次于皇冠。TOYOTA丰田,全球第一大汽车集团的出品,原车型是在日本广受好评的“MARK-X”系列,整体的档次定位就在同厂著名车系-凯美瑞之上(REIZ锐志是高于CAMRY凯美瑞,而仅低于CROWN皇冠的第二重量级车型)
在日本MARK X是一款运动型车,而国产后,MARK X被赋予了一个响亮的中文名――锐志(Reiz),同时在德语中意为“魅力”的“Reiz”也出现在车的尾部。这款车的定位区间(功能的对手/非单纯价格)非常的大,从十几万上下的宝来,到Mazda6、天籁、奥迪A4直到宝马530i,只要和运动沾边的车,都可以看作它的对手。
Reiz is the name of Japanese Toyota mark X after it was made in China. In October 2005, Reiz was produced and shared chassis with crown in Tianjin FAW Toyota No.2 factory. It is equipped with the same six speed automatic manual transmission as crown.
Mark X is the follow-up model of Mark II. It adopts the front and rear drive design. It ranks the third in the sales volume of all Toyota models, next only to crown in terms of positioning. Toyota, the world's largest automobile group, is the original model of the "mark-x" series, which is widely praised in Japan. The overall grade positioning is above the famous car series Camry of the same factory (Reiz is the second heavyweight car model higher than Camry Camry and only lower than crown crown)
In Japan, mark X is a sports car. After being made in China, mark X has been given a resounding Chinese name - Reiz. At the same time, Reiz, which means "charm" in German, also appears at the rear of the car. The positioning range of this car is very large, from Bora, Mazda6, Teana, Audi A4, to BMW 530i, as long as the car with sports can be regarded as its competitor.
相信大家看到过有车子停靠在停车场,而车身离地面十分接近,心里难免会充满好奇,车子是如何做到这么低的? 其实,原理就是车子改装了气动避震,能够自由升降车子的高度。下面就让我们一起欣赏一下丰田锐志 改装气动避震后的低趴效果。
I believe that you have seen a car parked in a parking lot, and the body is very close to the ground. You will inevitably be full of curiosity. How can the car be so low? In fact, the principle is that the car is refitted with pneumatic shock absorbers, which can freely lift the height of the car. Now let's enjoy the effect of Toyoda's refitting pneumatic shock absorber.
Let's break down the word hellaflush = Hella flush, that is, there are two parts, one is Hella, the other is flush. Hella is the abbreviation of "hell of", which means special, extraordinary, absolute and super; flush means flush. Therefore, two points should be understood here: 1. The formation of hellaflush must first satisfy the requirements of flush, that is, flat wheel tires, and then be qualified to make efforts from flush to hellaflush; 2. The body height must be as low as possible, and there must be no gap between the tire and the leaf plate from the side of the car.
