查看: 784|回复: 0
奥迪A3改装气动避震悬挂改装姿态的极致升华
发表于 2020-11-27 14:36:51 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
The ultimate sublimation of the modified attitude of Audi A3 pneumatic suspension
奥迪A3是奥迪出品的一款轿车产品,基于大众MQB平台研发,车身采用轻量化设计和铝制材料,动力上搭载1.4TFSI和1.8TFSI等多款发动机。
奥迪A3底盘前悬架为麦弗逊式,后桥为扭转、曲柄式结构带分开布置的弹簧和减振器,除了操纵性极佳外,后悬架布置的空间利用率也很高,因此载货面积在同级车中出类拔萃。所有A3系列车型,前后制动均为盘式,前制动带通风槽。
Audi A3 is a car product produced by Audi. It is developed based on the MQB platform of Volkswagen. Its body is made of lightweight design and aluminum material. It is equipped with 1.4tfsi and 1.8tfsi engines.
In addition to the front suspension and rear suspension, it is also equipped with the rear suspension of the Audi type, which is of the same class. For all A3 series models, the front and rear brakes are disc type, and the front brake is equipped with ventilation groove.
今天说道的这台 奥迪A3,经过AIRBFT气动避震的加持,将车身姿态降到了最低,简直是具有超跑颜值的一台小A3,  以贴地的美感博的玩家们的好感,视觉的强烈冲击和反常规状态引起强烈的共鸣,一起来欣赏 奥迪A3改装案例|气动避震悬挂改装姿态的极致升华。
Today's Audi A3, with the help of airbft pneumatic shock absorber, has reduced the body posture to the lowest level. It is a small A3 with super running appearance. It has a good feeling of touching the ground, strong visual impact and unconventional state. Let's enjoy the Audi A3 modification case | the ultimate sublimation of pneumatic shock absorber suspension modification posture.
