查看: 595|回复: 0
姥爷的低姿态 奔驰W211改装气动悬挂低姿态
发表于 2020-11-27 14:15:45 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
My grandfather's low profile Mercedes Benz W211 refitted with pneumatic suspension
当一台改装气动避震的车子静静的停在那里的时候,有很多的改装小白会惊叹:“这车怎么开呢?一个减速带不就死翘翘了?”带着疑问和惊讶,这是大多数改装新手的心声,当看到车主优雅的升高车身缓缓离去,我估计呢哥们该回家恶补改装知识了
当我们谈到汽车改装的时候,毫无疑问,风格对于一个改装迷来说就是一切。性能,舒适,外观,这些都是改装迷追求的对象,也是他们对自己个性的诠释。
气动避震改装“低趴范儿”在全球已经成为一种流行趋势,深受广大改装车迷追捧,它不仅能在视觉上给人一种强烈的冲击感,而且也能充分的展现出个性车主的独特品味。
When a car refitted with pneumatic shock absorber stops there quietly, there are a lot of refitted Xiaobai will wonder: "how can I drive this car? Isn't a speed bump dead? " With doubt and surprise, this is the voice of most novice refitters. When I see the owner's elegant body rising and slowly leaving, I guess it's time for my brother to go home and make up for the knowledge of refitting
When we talk about car refitting, there is no doubt that style is everything to a refitting fan. They are also interested in the appearance and performance of the fans.
Pneumatic shock absorber refitting "low prone fan" has become a popular trend in the world, and is deeply sought after by the majority of refitting fans. It can not only give people a strong visual impact, but also fully show the unique taste of individual car owners.
1: A good after-sales service system is a good one,
