查看: 743|回复: 0
别克英朗气动避震悬挂改装一览无余的美感
发表于 2020-11-24 15:51:36 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
别克英朗气动避震悬挂改装一览无余的美感
The aesthetic feeling of Buick yinglang pneumatic suspension refitting
别克英朗是别克品牌旗下继新君威、新君越以及昂科雷之后,第四款基于通用最新全球平台生产的车型,老款别克英朗源自欧宝新雅特,出自通用全球Delta Ⅱ平台。
全新别克英朗于2017年10月16日正式上市,新车采用全新家族式设计语言,首次引入通用全新一代1.3T/1.0T Ecotec双喷射涡轮增压发动机。并于2018年推出超级互联版车型。
“英朗”不仅诠释了这款五门轿跑车与生俱来的英姿焕发的气质及飒爽硬朗的线条和驾驭感受;同时也辉映出新一代奋斗青年的“才能和智慧”以及“敢想敢为、利落干脆的处事作风”。“英朗”的命名为别克品牌精神注入了新的时代内涵。
Buick yinglang is the fourth model of Buick brand based on GM's latest global platform after new Regal, new lacrosse and oncore. The old Buick yinglang is derived from Opel xinyate and comes from GM global Delta II platform.
The new Buick yinglang was officially launched on October 16, 2017. The new car adopts a new family style design language and introduces a new generation of 1.3t/1.0t ECOTEC dual injection turbocharged engine for the first time. And in 2018, the super Internet model will be launched.
"Yinglang" not only interprets the inherent heroic temperament and strong lines and driving experience of this five door coupe, but also reflects the "talent and wisdom" of the new generation of struggling young people and the "daring to think, dare to do, clean and simple style of doing things". The naming of "yinglang" has injected new era connotation into Buick brand spirit.
“英朗”不仅完美诠释了这款五门轿跑车与生俱来的英姿焕发的气质及飒爽硬朗的线条和驾驭感受;同时也辉映出新一代奋斗青年的“才能和智慧”以及“敢想敢为、利落干脆的处事作风”。“英朗”的命名为别克品牌精神注入了新的时代内涵. 别克英朗改装AIRBFT气动避震,三段记忆功能,稳定使用,高性价比,一起来欣赏一下它的改装魅力!
"Yinglang" is not only a perfect interpretation of this five door coupe's inherent heroic temperament and strong lines and driving experience, but also reflects the "talent and wisdom" of the new generation of struggling young people and the "daring to think, dare to do, clean and simple style of doing things". The name of "yinglang" injects new era connotation into Buick brand spirit. Buick yinglang refits airbft pneumatic shock absorber, three-stage memory function, stable use and high cost performance. Let's enjoy its refitting charm!
喜欢玩改装避震系统的发烧友,空气避震是话题里面最贵的一款。
听起来非常方便,气动避震到底是什么原理呢?
