查看: 683|回复: 0
宝马E38AIRBFT三段记忆手机app静音泵无缝鱼雷罐
发表于 2020-11-24 15:32:38 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
BMW e38airbft three segment memory phone app mute pump seamless torpedo tank
宝马 E38改装气动避震案例。E38是什么车?按照辈分来算,是目前贩售的7系的爷爷辈。经典的理由是什么呢?就是担任电影《玩命快递》第一部里头,杰森·斯坦森饰演的男主角出场开的车,不过电影里头那部是不带“L”的短轴,且据说是宝马特意为电影打造的手动版E38,市场上显然是打着灯笼都找不到的……如果你对那部电影有印象,就一定会E38刮目相看。
BMW E38 refitting pneumatic shock absorber case. What kind of car is E38? In terms of seniority, they are the grandfathers of the seven series currently on sale. What are the reasons for classics? It's the car that Jason stanson, the leading actor in the first movie of the movie "play for life express", drives the car. However, the short axis in the movie does not have an "L" and is said to be a manual version of E38 made by BMW specially for the film. Obviously, it can't be found in the market with lanterns If you have an impression of that film, you'll be impressed by E38.
气动避震的组成部分分为控制系统和气动避震桶身两大类!
在改装避震器主要选择分三种,分别是竞技短弹簧,套装,绞牙。这几种功能不同,价格也相差不少。选择适最适合自己的一款避震才是最重要的。那到底什么是适合自己的避震器呢?更换改装避震器后,首先要承担的就是舒适度损失,所以如果你还是对车辆舒适性比较追求的话那么在这里小编建议你还是不要更换的好,如果稍微损失一些没有什么问题的话,更换套装不仅可以提高车辆的操控性而且不会损失过多的舒适性。因为套装的出现,就是为在原车避震器的大结构上提高车辆的操控性能。不过避震套装也有许多不足,第一,售价略贵、第二,阻尼以及高低不可调整,第三,目前避震套装的选择,主要品牌还都集中在欧系车中,日系车套装并不热门。不过可能对许多资深玩家来说,避震套装已经完全不能够达到他们的需求,那么绞牙避震就成了他们的首选。绞牙这个词其实来源于中国的香港,其真正全称为Height. Adjustable. Damper有可调避震器阻尼段数以及车身高度的含义。看到这个名称我想我也没必要过多介绍它的功能了,全在名字里体现了。不过小编还是要插一句,更换绞牙避震后虽然可以得到理想的车身高度以及操控性能,但是却建立在损失百分之60的舒适上,所以更换前最好做好心理准备。
There are three main choices in refitting shock absorbers, which are competitive short spring, suit and twisted teeth. These functions are different and the prices are quite different. The most important thing is to choose the best one for yourself. So what is the right shock absorber for you? After replacing and refitting the shock absorber, the first thing to bear is the loss of comfort. Therefore, if you still pursue the comfort of the vehicle, then I suggest you don't replace it here. If there is no problem with a little loss, the replacement package can not only improve the handling of the vehicle, but also avoid losing too much comfort. Because the appearance of the suit is to improve the handling performance of the vehicle on the large structure of the original shock absorber. However, there are also many deficiencies in shock absorbers. First, the price is a little expensive. Second, damping and height can not be adjusted. Third, at present, the main brands of shock absorbers are still concentrated in European cars. Japanese car suits are not popular. However, for many senior players, the shock suit has not been able to meet their needs, so the first choice for them is to hang teeth. Actually, the word "twisted teeth" comes from Hong Kong, China. Its real full name is height. Adjustable. Damper, which means the number of damping segments of adjustable shock absorbers and body height. Seeing this name, I don't think I need to introduce its functions too much. It's all reflected in the name. However, Xiaobian has to add that although the ideal body height and handling performance can be obtained after replacing the hinge suspension, it is based on the loss of 60% of the comfort, so it is best to be psychologically prepared before replacement.
