查看: 592|回复: 0
野马改装气动避震低姿态精品案例分享
发表于 2020-11-23 14:46:50 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
野马改装气动避震低姿态精品案例分享
Mustang refit aerodynamic shock absorber low profile boutique case sharing
In 1962, Ford developed Mustang I, the first concept car for Mustang. It is a two seat sports car in the middle of the engine. The name of Mustang is to commemorate the legendary U.S. P-51 Mustang fighter in World War II.
总是发“趴”在地上的车好多人不理解疑问也多,就通俗易懂的解释一下,气动,通过改装四支“空气避震+控制器”从而达到在车内随意调节车身高度的目的。很多品牌高端配置车型也会有,它叫做“底盘升降”差别在哪?升的没我们高,降的没我们低,升降速度没我们快。 下面是福特野马改装气动避震的低姿态颜值,有野马车的,并且喜欢低姿态的车友可以参考一下!
A lot of people don't understand and have a lot of questions about the car that is always lying on the ground. It is easy to explain that pneumatic, by refitting four "air shock absorbers + controllers", can achieve the purpose of adjusting the height of the body in the car at will. Many brands have high-end configuration models, which are called "chassis lifting". What is the difference? The rising is not as high as ours, the descending is not as low as ours, and the ascending and descending speed is not as fast as ours. The following is the Ford Mustang modified pneumatic shock absorbers of low-profile beauty, there are Mustang, and like low-profile riders can refer to it!
