查看: 584|回复: 0
大众甲壳虫改装AIRBFT气动避震完美落地
发表于 2020-11-23 14:17:50 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Volkswagen Beetle modified airbft pneumatic shock absorber landing perfectly
大众甲壳虫(Volkswagen Beetle)正式名称为大众1型(Volkswagen Type 1),是由大众汽车(香港译福士车厂)在1938年至2003年间生产的一款紧凑型轿车。1998年,在最初的甲壳虫下线许多年以后,大众汽车正式推出了外形与原先非常相似的新甲壳虫(以大众高尔夫(Golf)为平台),而甲壳虫则在墨西哥和其他少数一些国家一直生产到2003年。在评选最具世界影响力的“20世纪汽车”的国际投票中,甲壳虫排名第四,仅次于福特T型车、迷你和雪铁龙DS。
The official name of Volkswagen Beetle is Volkswagen type 1. It is a compact car produced by Volkswagen from 1938 to 2003. The beetle was originally launched in Mexico in 1998, and a few of the beetles were officially launched in Mexico in 1998, with a number of new beetles produced in the country. In the international vote for the most influential "20th century car," the beetle ranked fourth, behind Ford's Model T, mini and Citroen DS.
下面的这台甲壳虫改装气动避震,顾名思义就是利用空气的动能来支撑车体的,气动避震的改装是利用橡胶气囊来代替原车的弹簧,通过一套气压控制系统来实现车子底盘的升高和降低的,路况不好的时候可以升高车身来增强通过性,高速行驶的时候可以适当的降车身来增强稳定性,另外一个最显著的特点就是停车的时候把车子降到最低,视觉效果非常的突出,车友就是被气动避震改装的低姿态所征服的,下面就一起来看甲壳虫的姿态吧,当之无愧的低趴萌宠!
The following beetle refits the pneumatic shock absorber. As the name implies, it uses the kinetic energy of the air to support the car body. The pneumatic shock absorber refitting uses the rubber air bag to replace the spring of the original car. Through a set of air pressure control system, the chassis of the car can be raised and lowered. When the road condition is bad, the body can be raised to enhance the trafficability, and it can be properly lowered when driving at high speed  the body is used to enhance the stability. Another prominent feature is to reduce the car to the minimum when parking. The visual effect is very prominent. The riders are conquered by the low attitude of pneumatic shock absorber. Let's take a look at the posture of the beetle, which is worthy of low lying and cute pet!
Hellaflush has become an international appearance trend of refitted cars. With the development and progress of domestic refitted cars, more and more are accepted by the public. HF model has also become a symbol of taste
