查看: 619|回复: 0
12代皇冠倾心打造完美HF风格改装气动避震配置案例
发表于 2020-11-23 14:06:21 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
12th generation crown devoted to creating perfect HF style and refitting pneumatic shock absorber configuration
改装气动避震悬挂的客户一般要求姿态也要兼顾舒适性,这样的要求可谓很难达到,因为车型不同效果肯定就会有所不同,气动避震改装主要就是为了低姿态,很多玩家只能退求其次。 12代皇冠安装AIRBFT气压避震桶身搭配AIRBFT控制系统, 反馈舒适性比原车好很多,开起来相当舒服,低趴效果也是相当好,绝对的改装首选,值的推荐!
Customers who refit the pneumatic suspension generally require that the posture should also take into account the comfort, so it is very difficult to meet the requirements, because the effect will be different with different models. The main purpose of pneumatic shock absorber modification is to lower the posture, and many players can only ask for the second. The 12th generation crown is equipped with airbft pneumatic shock absorber barrel body and airbft control system. The feedback comfort is much better than the original car. It is very comfortable to drive, and the low prone effect is also very good. It is absolutely the first choice for refitting. It is worth recommending!
