查看: 662|回复: 0
克莱斯勒300C改装AIRBFT气动避震完工
发表于 2020-11-20 16:04:37 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Chrysler 300C modified airbft pneumatic shock absorber completed
进口克莱斯勒300c,秉承“大胆创新 自成潮流”的品牌理念,克莱斯勒品牌携其旗舰产品——全新进口克莱斯勒300C,重返中国市场。这款全新300C无论在设计、性能还是做工品质,都将“非同质化”的造车理念发挥到极致。
为那些通过创新和智慧获得成功,更推动和引领各自行业潮流的发展,并勇于彰显自身内在独有特质与个性的中国新一代企业家和国际精英,提供了一款“非同质化”的豪华性能座驾。
据介绍,进口克莱斯勒300C是克莱斯勒公司投入10亿美金打造的其品牌史上最豪华的一款产品,迄今已获得56项海外权威机构的大奖:其中不仅包括北美“2012年最值得购买车型”的称号,更被北美最权威的消费导购刊物《消费者报告》评为“近二十年来最好的克莱斯勒轿车”。值得一提的是,进口克莱斯勒300C获得了“全球十佳内饰”及“全球十佳发动机”的”双十佳”殊荣。
The imported Chrysler 300C, adhering to the brand concept of "bold innovation and self trend", has returned to the Chinese market with its flagship product, newly imported Chrysler 300C. This new 300C will bring the concept of "non homogeneity" into full play in terms of design, performance and workmanship quality.
For the new generation of Chinese entrepreneurs and international elites who have achieved success through innovation and wisdom, promoted and led the development of their own industry trends, and have the courage to show their own unique characteristics and personality, it provides a "non homogeneity" luxury performance car.
According to reports, the imported Chrysler 300C is the most luxurious product in the history of Chrysler's brand, which has invested 1 billion US dollars. So far, it has won 56 awards from overseas authoritative organizations, including not only the title of "the most worthwhile model to buy in 2012" in North America, but also the "best Kress in the past 20 years" by consumer report, the most authoritative consumer guide in North America Le sedan ". It is worth mentioning that the imported Chrysler 300C has won the "world's top 10 interior decoration" and "double top 10 engine" awards.
我一直认为,汽车改装是一种追求,一种对个性的追求,或者是满足自己虚荣心的一种方式。
今天说说要说的改装就是汽车避震的改装。汽车避震的改装相对来说比较特殊,因为它既能兼顾性能,又能兼顾外观,可以说是双赢。
I have always believed that car refitting is a pursuit, a pursuit of individuality, or a way to satisfy one's vanity.
Today's talk about the modification is the modification of the car shock absorber. The modification of automobile shock absorber is relatively special, because it can take into account both performance and appearance, which can be said to be a win-win situation.
喜欢玩改装避震系统的发烧友,空气避震是话题里面最贵的一款。
听起来非常方便,气动避震到底是什么原理呢?
