查看: 682|回复: 0
奔驰威霆安装AIRBFT空气悬挂套件,提升舒适首选
发表于 2020-11-20 15:36:55 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
The first choice for improving comfort is to install airbft air suspension package
奔驰威霆是德国奔驰推出的一款MPV,于2010年推出,定位“专业级MPV”梅赛德斯-奔驰威霆(Vito)  ,是福建奔驰旗下的明星产品。轴距长3430mm,车内空间宽大,7-9座设置满足团体出行需求。
福建奔驰威霆采用了“简洁+大气”的设计风格。全新鹰式造型头灯一改过去水滴头灯形状,尽显大气和犀利。而前大灯和尾灯之间的两条独具匠心的设计线条,让车身动感十足。全新刀锋造型的两片式进气格栅造型给车辆赋予了一份干练和健硕的气质。
凭借“尊而不贵”的高性价比、卓越的性能、稳健大气的外观、优异的安全可靠性,威霆自上市至今受到众多行业用户的青睐,也多次获得行业机构的肯定。
Mercedes Benz Vito is a MPV launched by German Benz in 2010, positioning "professional MPV" Mercedes Benz Vito. It is a star product of Fujian Benz. The wheelbase is 3430mm long and the interior space is wide. 7-9 seats are set to meet the needs of group travel.
Fujian Benz Weiting adopts the design style of "simplicity + atmosphere". The new Eagle shaped headlamp changes the shape of the water drop headlamp, showing the atmosphere and sharpness. And the two unique design lines between the front headlight and the tail lamp make the body dynamic. The new blade shape of the two-piece air intake grille gives the vehicle a capable and strong temperament.
With "respect but not expensive" high cost performance, excellent performance, stable and atmospheric appearance, excellent safety and reliability, Weiting has been favored by many industry users since its listing, and has been affirmed by industry organizations for many times.
关于舒适度,我觉得要分两个部分,一个是驾驶的舒适度,可以理解为转向精准、油门响应速度快等驾驶感受。还有一个就是乘坐的舒适度,我想,买威霆或者V260的车友,肯定和我一样,更加在意的是乘坐的舒适度,因此我就重点说说如何提升乘坐的舒适度。气动配合好轮毂的尺寸和数据可以把车降到最低。静止时,把车降到最低趴在地上,帅。行驶时,根据路况任意调节喜欢的高度。
As for comfort, I think it can be divided into two parts. One is driving comfort, which can be understood as driving experience such as accurate steering and fast response of accelerator. The other is the ride comfort. I think that the same as me, the riders who buy Weiting or V260 pay more attention to the ride comfort. Therefore, I will focus on how to improve the ride comfort. Pneumatic matching wheel hub size and data can reduce the car to the minimum. When stationary, lower the car to the lowest, lying on the ground, handsome. When driving, adjust the height you like according to the road conditions.
气动避震的组成部分为控制系统和气动避震桶身两大类!
Pneumatic shock absorber consists of control system and pneumatic shock absorber barrel body!
Intelligent air replenishment and intelligent adjustment of vehicle level: in fact, the functions of these two functions are the same. For example, the body height is originally horizontal. If a fat man sits in the rear seat, the height of the rear side will be reduced. At this time, the computer will detect the height change at the rear, and respond in less than one second. The two air bags at the back will be inflated to maintain it Body level!
The ignition will automatically rise to the set position height: such a function is no matter what kind of height you park, such as the lowest or the highest, when you stop, get off, and drive again, the system will automatically raise the car to the second gear position, that is, the height of the normal car! This has both advantages and disadvantages. For example, the road condition is very bad. There is no suitable parking space. When parking, stop at the highest position. When you drive again, the system will automatically decrease. If you just stop at a very high rural cement deceleration belt, it is very likely to or directly support the bottom! The advantage is that in a normal parking lot, the parking car will be lowered to the lowest level. When driving again, the train will automatically rise to the normal driving height. Think about how high this force is
One button to the lowest: one button, you can reduce the car to the lowest state! There is a one button down button on the control panel. If you press and hold for 3 seconds, the whole car will be in the lowest state! Why three seconds? Because this is to prevent misoperation. If your car is running, if a child or some special situation accidentally touches the one button lowering button, it is a very terrible thing. In this way, this kind of design can completely avoid this kind of situation. It doesn't matter if you touch all the buttons carelessly, as long as you don't press it for a long time!
