查看: 762|回复: 0
皇冠133非承载车身改装AIRBFT气动避震简直帅的没朋友,年代感的回味真的是一种享受
发表于 2020-11-19 14:52:30 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Crown 133 non load bearing body modified airbft pneumatic shock absorber is simply handsome, no friends, the aftertaste of the age is really a kind of enjoyment
当提到丰田皇冠133,对于一些生活在中国的沿海地区或者内地部分发达地区的80/90后来说,绝对并不陌生。经典的外形设计、经久耐用的品质,一直以来它都获得了不少车迷的良好评价。虽然随着科技发展,如今要在国内的道路上看到一辆依然行走在路上的133已经越来越难了。但一些老车爱好者,却会想尽办法地找一辆133回来,通过翻新让它可以继续生存下去。
When it comes to Toyota Crown 133, it is no stranger to the 80 / 90 generation who live in China's coastal areas or some developed areas in the mainland. Classic shape design, durable quality, it has been a lot of fans have been good evaluation. Although with the development of science and technology, it is becoming more and more difficult to see a 133 still on the road in China. However, some old car enthusiasts will try their best to find a 133 to come back and renovate it so that it can continue to survive.
喜欢玩改装避震系统的发烧友,空气避震是话题里面最贵的一款。
听起来非常方便,气动避震到底是什么原理呢?
What is the principle of pneumatic shock absorption?
If the air pressure in the tank is not stable, it will easily lead to air leakage.
