查看: 658|回复: 0
宝马改装气动避震 引领低趴改装潮
发表于 2020-11-19 14:06:41 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
宝马改装气动避震 引领低趴改装潮
BMW refits pneumatic shock absorber to lead the trend of low lying refitting
宝马(BMW),德国豪华汽车品牌,宝马的车系有i、X、Z、纯数字4个车型,1、2、3、4、5、6、7、8等几个系列,还有在各系基础上进行改进的M系(宝马官方的高性能改装部门),宝马公司创建于1916年,总部设在德国巴伐利亚州慕尼黑,BMW的蓝白标志宝马总部所在地巴伐利亚州州旗的颜色,百年来,宝马汽车由最初的一家飞机引擎生产厂发展成为以高级轿车为主导,并生产享誉全球的飞机引擎、越野车和摩托车的企业集团,名列世界汽车公司前列,其全称为die Bayerischen Motorenwerke (Bavarian Motor Work)。
BMW (BMW), a German luxury car brand, has four series of I, x, Z and pure digital models, 1, 2, 3, 4, 5, 6, 7, 8 and other series, as well as the M-series (the official high-performance refitting Department of BMW) which has been improved on the basis of each series. BMW company was founded in 1916, and its headquarters are located in Munich, Bavaria, Germany The color of Bavarian State flag. Over the past 100 years, BMW has developed from an initial aircraft engine manufacturer to an enterprise group with high-end cars as the leading company and producing world-famous aircraft engines, SUVs and motorcycles. It ranks among the top auto companies in the world, and its full name is die Bayerischen motornwerke (Bavarian motor work).
气压避震改装风格发展至今,总体出现两个方向,一类是低趴的车身配合夸张的宽体或相对凸显战斗气息;而另一种则是尽量保证车身的干净、整洁,以原厂升级或进行少许替换,将原厂的设计风格保留。眼前这台宝马改装便是遵循了后者的思路,在基础上进行了气压避震的改装,使车身呈现出十分干净整洁而且高贵的低趴效果。
Up to now, there are two directions in the development of pneumatic shock absorber refitting style. One is the low lying body with exaggerated wide body or relatively highlighting the fighting atmosphere; the other is to try to ensure that the body is clean and tidy, upgrade or replace it with the original factory, so as to retain the original design style. At present, the refitting of this BMW follows the idea of the latter. On the basis of this, the modification of pneumatic shock absorber is carried out, which makes the body present a very clean, clean and noble low lying effect.
Airbft special car special leather bag, the use of natural rubber ingredients than tire natural rubber ingredients more! Single fatigue 5 million times to 8 million times, normal use of 3-5 years, no problem! After strict testing equipment to test pressure, full pressure can be sold! The outer layer of the leather hoop is made of anti-corrosion material and has a high water-proof lock!
