查看: 730|回复: 0
新款雷克萨斯IS300气动避震悬挂改装 低姿态就是这么美让你一眼难忘
发表于 2020-11-18 16:42:50 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
The new Lexus is300 pneumatic suspension is so beautiful that you can never forget it
下面的这台新款雷克萨斯IS300改装是气动避震,在气动避震的作用下将一台车子的姿态将到最低来玩Hellaflush低趴姿态的改装风格,这也是当下最为流行的改装方式,很多车友聚会或者是大型的改装车展,轿车大都是以改装气动避震玩低趴姿态为主!
The following new Lexus is300 refit is pneumatic shock absorber. Under the effect of pneumatic shock absorber, the posture of a car will be minimized to play hellaflush low lying posture modification style. This is also the most popular modification method at present. Many car friends gather or large-scale refit auto show, most cars are modified pneumatic shock absorbers to play low lying posture!
汽车避震是由弹簧和减震器共同组成的。
