查看: 689|回复: 0
"心中永远的最强情怀"大众高尔夫R32安装气动避震让姿态更加优雅
发表于 2020-11-18 16:13:17 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
"The strongest feeling in the heart forever" Volkswagen Golf R32 installation pneumatic shock absorber makes posture more elegant
R32的第一次亮相,几乎把所有的人都惊呆了,对于GTI的拥护者来说,R32简直就是大众跟自己开的一个玩笑,一旦买了R32之后,你就不用去添置OZ的18英寸轮毂、大口径的制动卡钳、双口排气管、Recaro的筒式座椅……改装配件,因为从R32上你都可以得到,并且都是大众原厂产品。
The first appearance of R32 shocked almost everyone. For GTI supporters, R32 is just a joke made by the public. Once you buy the R32, you don't need to buy Oz's 18 inch wheel hub, large caliber brake calipers, double port exhaust pipe, Recaro bucket seat Refit accessories, because you can get them from R32, and they are all original products of Volkswagen.
There is a popular saying in the field of refitting that "100 changes should be reduced to the first". I will add that low lying is the king's way! If there is no pneumatic shock absorber refitting, I feel like a walking corpse, with a bright appearance and no soul! The so-called ugliness is the key to improve the quality of the car!
喜欢玩改装避震系统的发烧友,空气避震是话题里面最贵的一款。
听起来非常方便,气动避震到底是什么原理呢?
