查看: 647|回复: 0
又见“HF” 奔驰S205改装AIRBFT气动避震的低趴风格魅力案例
发表于 2020-11-18 15:28:32 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
See also the case of "HF" Benz S205 refitting airbft pneumatic shock absorber with low prone style
在这个时代想要引人注目,没有独特的改装是无法给人深刻的印象的。对于轿车的车主来说,仅仅将S级作为代步工具的话只会显得自己的生活淡而无味,S205改装了SF气动避震专用版本避震器, 控制系统+AIRBFT定制皮囊+SF绞牙避震。极限低趴、舒适、操控、体验度、稳定性、变身SUV?都不在话下。追求个性,享受驾车的愉悦才是奔驰S应有的生活态度。
In this era, if you want to be conspicuous, you can't make a deep impression without a unique modification. For car owners, only using S-class as a walking tool will make their life dull. S205 has refitted SF pneumatic shock absorber special version shock absorber, control system + airbft customized leather bag + SF twisted teeth shock absorber. Extreme low lying down, comfort, handling, experience, stability, transformation SUV? It's nothing. Pursuing individuality and enjoying the pleasure of driving are the life attitude of Mercedes Benz s.
