查看: 721|回复: 0
Porsche panamera改装气动避震悬挂 超跑的贴地姿态
发表于 2020-11-18 15:15:16 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Modified pneumatic suspension of the Porsche Panamera
保时捷Panamera是一款轿车,保时捷PANAMERA车身线条圆润流畅,没有任何棱角,显示出比较成熟的保时捷设计风格。全新保时捷Panamera将装配米其林为该款车型定制设计的米其林Pilot Sport和米其林Pilot Alpin轮胎。
它采用了四门设计,前脸两侧各有一个大型进气口,水平条式雾灯横穿其中,造型独特。侧身线面处理得简洁柔和,既优雅又动感,巨大的五辐式轮彀搭配了黑色的刹车卡钳,暗示出不俗的运动潜能。与其它保时捷车型一样,新Panamera的内部结构采用了传统的钢制承载式车身结构。
The Panamera is a car. The lines of the Panamera are smooth and smooth without any edges and corners, showing a relatively mature design style of Porsche. The all new Panamera will be equipped with Michelin pilot sport and Michelin pilot Alpin tires designed for this model.
It adopts a four door design, with a large air inlet on both sides of the front face, and the horizontal bar fog lamp traverses it with unique shape. The side line is simple and soft, elegant and dynamic. The huge five spoke hub with black brake calipers indicates great sports potential. Like other Porsche models, the interior structure of the new Panamera adopts the traditional steel carrying body structure.
超跑底盘本身设计的就很低,但是为了展现更美的姿态,保时捷帕拉梅拉改装AIRBFT气动避震悬挂,降低车身,发现更美的姿态。低趴才是王道,贴地才是追求!
The super running chassis itself is designed to be very low, but in order to show a more beautiful posture, the Porsche palamera modified airbft pneumatic suspension to lower the body and find a more beautiful posture. Low lying is the king, sticking to the ground is the pursuit!
N ew airbft three segment memory version control:
