查看: 724|回复: 0
十代雅阁安装气动避震,一键低趴,真是太帅了!
发表于 2020-11-16 16:05:26 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Ten generations of accord installation pneumatic shock absorbers, one button low prone, really handsome!
汽车改装属于汽车后市场的一种产物,许多车型因为原厂的设计比较平庸,不能满足玩家的要求,因此就出现了改装行业的繁荣现象,气动避震悬挂的改装属于一种外观的姿态改装,以贴地的美感博的玩家们的好感,视觉的强烈冲击和反常规状态引起强烈的共鸣,一起来欣赏 改装案例|十代 雅阁气动避震低趴风格改装
Car refitting is a product of the automotive aftermarket. Many models can't meet the requirements of the players because of the mediocre design of the original factory. Therefore, the refitting of the pneumatic shock absorber suspension is a kind of appearance posture modification, which causes strong resonance with the good feeling of the players close to the ground, strong visual impact and unconventional state, Let's enjoy the refitting case
减震器的工作原理主要用来抑制弹簧吸震后反弹时的震荡及来自路面的冲击。在经过不平路面时,虽然吸震弹簧可以过滤路面的震动,但弹簧自身还会有往复运动,而减震器就是用来抑制这种弹簧跳跃的。减震器的种类从产生阻尼材料的角度划分,减震器主要有液压和充气两种。
The working principle of the shock absorber is mainly used to suppress the shock of spring rebound and the impact from the road. Although the shock absorption spring can filter the vibration of the road surface when passing through the uneven road surface, the spring itself will have reciprocating motion, and the shock absorber is used to restrain the spring jumping. The types of shock absorbers are divided from the angle of producing damping materials. There are mainly two kinds of shock absorbers: hydraulic and pneumatic.
