查看: 648|回复: 0
越野中王者途乐Y65改装气动避震走低趴路线
发表于 2020-11-16 15:54:07 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Off Road King Tule y65 refitting pneumatic shock absorber to walk low
途乐,越野利器,穿沙神器,穿越必备,但是,赛道上,他好像不太行,在城市里,玩的也不多,今天,这台沪牌的途乐,爱上了低姿态,让这台途乐更有赛道范,告别越野。
Toule, a cross-country weapon, is a must-have tool for crossing. However, on the track, he doesn't seem to be very good. In the city, he doesn't play much. Today, this Shanghai brand Tule fell in love with the low attitude, which makes the Toure more racetrack style and bid farewell to cross-country.
喜欢玩改装避震系统的发烧友,空气避震是话题里面最贵的一款。
听起来非常方便,气动避震到底是什么原理呢?
因为气动避震是比较精密的部件,有气罐装置,不适合在颠簸路段进行剧烈的驾驶。容易导致慢性漏气,引起气压不稳定,气罐内的温度会升高,气动调节就会失去精准度。
One of the most expensive topics is the air shock absorber.
Because the pneumatic shock absorber is a more precise part and has an air tank device, it is not suitable for severe driving on bumpy roads. It is easy to cause chronic air leakage and unstable air pressure. The temperature in the air tank will rise, and the accuracy of pneumatic regulation will be lost.
