查看: 840|回复: 0
W222奔驰S改装气动避震姿态魅力给人眼前一亮
发表于 2020-11-16 15:07:43 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
W222 Mercedes Benz S refitted with aerodynamic shock absorbers
作为奔驰W221的继任者,第十代奔驰S级W222的设计工作从2009年就已经开始展开,由Il-hun Yoon和Robert Lesnik执笔设计的第十代奔驰S级让世人再次领略到奔驰这一旗舰车型不凡的王者魅力。
As the successor of Mercedes Benz w221, the design work of the 10th generation Mercedes Benz S-class w222 has been started since 2009. The design of the 10th generation Mercedes Benz S-class, written by IL Hun Yoon and Robert lesnik, let the world once again appreciate the extraordinary charm of Mercedes Benz, the flagship model.
喜欢玩改装避震系统的发烧友,空气避震是话题里面最贵的一款。
听起来非常方便,气动避震到底是什么原理呢?
One of the most expensive topics is the air shock absorber.
