查看: 803|回复: 0
起亚K5AIRBFT气动避震改装效果超你所想
发表于 2020-11-15 15:43:28 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
The effect of Kia k5airbft pneumatic shock absorber is better than you think
起亚K5是东风悦达起亚旗下的一款中高级轿车,高腰线、强张力的设计让K5更趋动感,体现出来一种朝气与活力,这一款重量级的车型即将在2011年3月份上市。此车外形变动很大,更加时尚前卫,整体风格偏于运动,相当具有竞争力。
Kia K5 is a medium and high-end sedan owned by Dongfeng Yueda Kia. The design of high waistline and strong tension makes K5 more dynamic, reflecting a kind of vigor and vitality. This heavyweight model will be launched in March 2011. The shape of this car changes a lot, more fashionable and avant-garde, the overall style of sports, quite competitive.
说到低姿态改装,最具代表性的肯定是气动避震悬挂,能升能降,在享受低趴美的同时不影响日常使用,可谓一举两得,今天就来介绍一下起亚K5改装AIRBFT气动避震的案例,低趴效果完美展现!
When it comes to low attitude refitting, the most representative is pneumatic shock absorber suspension, which can rise and fall. It can kill two birds with one stone while enjoying the beauty of low lying down without affecting the daily use. Today, let's introduce the case of Kia K5 refitting airbft pneumatic shock absorber, and the low lying effect is perfectly displayed!
Let's talk about the installation of pneumatic shock absorber. The installation of pneumatic shock absorber barrel body is actually the same as that of replacing ordinary hinge suspension. Shock absorbers are all the installation positions of the original vehicle. It should be noted that the highest and lowest range required by the owner of the vehicle should be calculated according to the shock absorber travel, so as to adjust the height of the solar shock absorber, as well as the reserved position of the air pipe. Generally, the air pipe moves on the inner side The rest is to follow the normal shock absorber installation procedures.
The laying of pipelines and pipelines is a time-consuming work. The methods and ideas of each installation master are different. However, one principle should be followed, that is, to avoid the places that may be bent dead or where the vehicle may be pressed or ground to the air pipe, and that is, to keep away from the exhaust gas, because the material of the gas pipe is prone to high temperature, the best way is to It's going with the tubing.
When the line moves, the line usually goes in the car, along with the electrical circuit in the car, which is quite troublesome, because it is necessary to dismantle a lot of interior parts. It is better not to cut off the main power line. In addition, if there are other electrical equipment in the car, the power line must not be shared to prevent mutual interference.
For the installation of control system, airbft pneumatic shock absorber control system is a simple control system. However, if you want to perfect the installation, you need to have some experience, because there are many details that need to be paid attention to, especially the screw thread connection of each joint, air pipe and air hole, should be carefully installed. The screw tooth connection of air hole and joint must be well sealed, and if there is leakage Gas condition, and then check the test, is very troublesome, as far as possible one step in place.
