查看: 678|回复: 0
宝马M4带您走进气动避震改装的那些精彩世界
发表于 2020-11-15 14:49:23 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
BMW M4 brings you into the wonderful world of pneumatic shock absorber modification
宝马m4是一款进口轿车,有双门轿跑、敞篷轿跑,2014年8月21日,正式宣布进口上市销售,特选米其林Pilot Super Sport作为原厂标配轮胎。
其中M4双门轿跑价格为102.7万元,M4敞篷轿跑价格为113万元。新车均基于新3系打造,并加入了最新的M运动套件,同时还搭载了3.0T双涡轮增压发动机,上一代经典的V8自然吸气发动机将缺席
BMW M4 is an imported car, with two door sedan and open top sedan. On August 21, 2014, it was officially announced that it was imported and put into the market. Michelin pilot super sport was selected as the standard tire of the original factory.
Among them, the price of M4 double door sedan is 1.027 million yuan, and that of M4 convertible car is 1.13 million yuan. The new cars are all built on the new 3-series, with the latest m sports kit, and also equipped with a 3.0T twin turbocharged engine. The previous generation of classic V8 naturally aspirated engine will be absent
对于宝马M4改装气动避震悬挂你了解多少呢?看看这辆国外改装气动避震的M4低趴魅力。 并加入了最新的M运动套件,同时还搭载了3.0T双涡轮增压发动机,上一代经典的V8自然吸气发动机将缺席。最新M4带您走进气动避震改装的世界
How much do you know about the modified pneumatic suspension of BMW M4? Take a look at the M4 low lying charm of the foreign refitted pneumatic shock absorber. In addition, the latest m sports package is added, and a 3.0T twin turbocharged engine is also equipped. The last generation of classic V8 naturally aspirated engine will be absent. The latest M4 brings you into the world of pneumatic shock absorbers
正所谓一低遮百丑
这几年HF改装火遍大街小巷
气动减震
也是一夜变身改装界网红
Pneumatic shock absorption
话说这是个什么东西呢?
它其实是一套可以控制气压
改变车身高低的装置
与传说中的主动车身控制系统(ABC)类似
不过它的工作介质是气体
一般来说就是下图所示的这么一套家伙事
其中包括弹性橡胶气囊减震器
气压控制系统、后备箱储气罐
及电子控制系统等
它其实和空气减震的原理与常见减震器
螺旋弹簧+减震筒形式
原理十分类似
只不过
通过改变气室体积(上下方向)
来调整车身离地距离并一定程度改变软硬特性
另外减震筒部分则可以由电机改变通气孔尺寸
从而调节减震器的衰减力
因此空气减震器往往
能提供更好的性能表现
嗯!就是这么自信
So what is this?
But its working medium is gas
And electronic control system
The principle is very similar
It's just
Yeah! So confident
