查看: 619|回复: 0
奥迪A3气动避震悬挂改装姿态的极致升华
发表于 2020-11-15 14:31:20 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
奥迪A3气动避震悬挂改装姿态的极致升华
The ultimate sublimation of modified attitude of Audi A3 pneumatic suspension
奥迪A3是奥迪出品的一款轿车产品,基于大众MQB平台研发,车身采用轻量化设计和铝制材料,动力上搭载1.4TFSI和1.8TFSI等多款发动机。
奥迪A3底盘前悬架为麦弗逊式,后桥为扭转、曲柄式结构带分开布置的弹簧和减振器,除了操纵性极佳外,后悬架布置的空间利用率也很高,因此载货面积在同级车中出类拔萃。所有A3系列车型,前后制动均为盘式,前制动带通风槽。
Audi A3 is a car product produced by Audi. It is developed based on the MQB platform of Volkswagen. Its body is made of lightweight design and aluminum material. It is equipped with 1.4tfsi and 1.8tfsi engines.
The front suspension of Audi A3 chassis is McPherson type, and the rear axle is of torsion and crank structure with separate springs and shock absorbers. In addition to excellent maneuverability, the space utilization rate of rear suspension layout is also very high, so the loading area is outstanding among the same class of vehicles. For all A3 series models, the front and rear brakes are disc type, and the front brake is equipped with ventilation groove.
气动避震的改装从来都没有哪些条条框框,是门讲究走心、讲究个性的艺术。只要你能想得到,便可通过双手逐一实现,去完成内心中最为完美的艺术品。但改装绝非一日之功,而是需要不断的完善,是一点一点的堆砌才能呈现出来的。下面这台奥迪A3,其车主从改装计划的设想,到改装件的等待,再到没日没夜的不断完善车身每一处细节,无一不是心血的流淌,是对极致的不屑追求。但是到目前还没有达到终极的低姿态,正所谓改装无极限!
There are no rules and regulations in the refitting of pneumatic shock absorbers. It is a kind of art that pays attention to deviation and individuality. As long as you can think of it, you can achieve it one by one with both hands to complete the most perfect artwork in your heart. But refitting is not a day's work, but need to be constantly improved, is a little bit of stacking to show. The following Audi A3, its owner from the idea of the modification plan, to the waiting for the modified parts, and then to the continuous improvement of every detail of the body day and night, is the flow of painstaking efforts, is the disdain pursuit of the ultimate. But up to now, it has not reached the ultimate low attitude, just as the so-called refitting has no limit!
