查看: 588|回复: 0
BENZ W204改装气动避震 完美低身姿演绎经典
发表于 2020-11-15 14:18:28 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Benz W204 refitted pneumatic shock absorber, perfect low body posture, deduce classic
在这个以低为美的时代,改装车已经成为我们一种习惯,俗话讲“百改降为先”对一辆车改装前一定要先降低身姿,以前是选用绞牙避震来达到这一效果,不过改绞牙影响日常的使用,所以现在最棒的降低车身的改装方法就是气动避震的改装,既能达到降低车身的效果,完美贴地,还能提升舒适,简直完美无敌。今天我们来看看老款奔驰C级W204改装气动避震的迷人身姿。
In this era of low for beauty, refitting cars has become a habit for us. As the saying goes, "one hundred changes should be reduced to the first". Before refitting a car, we must first reduce the body posture. In the past, we used to use the twisted teeth to achieve this effect. However, changing the twisted teeth affects the daily use. Therefore, the best way to reduce the body weight is to refit the pneumatic shock absorber, which can reduce the body size The effect is perfect, and it can also improve the comfort. It's absolutely perfect. Today, let's take a look at the charming body of the old Mercedes Benz C-class W204 refitted with pneumatic shock absorber.
Let's break down the word hellaflush = Hella flush, that is, there are two parts, one is Hella, the other is flush. Hella is the abbreviation of "hell of", which means special, extraordinary, absolute and super; flush means flush. Therefore, two points should be understood here: 1. The formation of hellaflush must first satisfy the requirements of flush, that is, flat wheel tires, and then be qualified to make efforts from flush to hellaflush; 2. The body height must be as low as possible, and there must be no gap between the tire and the leaf plate from the side of the car.
