查看: 549|回复: 0
奔驰GLC改装气动避震悬挂低趴魅力姿态的极致升华
发表于 2020-11-15 13:46:18 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Mercedes Benz GLC modified pneumatic shock absorber suspension, the ultimate sublimation of charming posture
奔驰GLC是奔驰推出的首款全新跨界车型,2015款发布。奔驰GLC实质上可以看做是GLK的轿跑版,而之所以奔驰GLC要到2016年才会问世。
奔驰正在计划主要依靠其SUV与跨界车,推出的首款全新跨界车型是2015款奔驰GLC。
Mercedes Benz GLC is the first new crossover model launched by Mercedes Benz, with 2015 model released. Mercedes Benz GLC can be regarded as the car running version of GLK in essence, and the reason why Benz GLC will not come out until 2016.
Mercedes Benz is planning to rely mainly on its SUVs and crossover vehicles, and the first new crossover model launched is the 2015 Mercedes Benz GLC.
下面说道的是改装气动避震的奔驰GLC ,因为一成不变的车生活枯燥无味,如果不来点改变,就如同行尸走肉,所以这台SUV不在SUV了,改装气动避震降低车身玩姿态!大家看到这么低的车身肯定会有疑问,这怎么开呢? 其实他还是SUV,在气动避震的作用下可以随时的升高和降低车身,静止的时候可以把车身降到最低来玩低趴!正常用车的时候可以及时的升高车身,升高之后对日常的用车一点影响都没有!
If the suglv doesn't change into a car body, it will be boring to change its body posture!
When you see such a low body, you will have doubts. How can you drive it? In fact, it is an SUV, which can raise and lower the body at any time under the effect of pneumatic shock absorber, and can lower the body to the lowest when it is still to play low lying down! When you use a car normally, you can raise the car body in time. After that, it has no effect on the daily use of the car!
