查看: 579|回复: 0
帕萨特B5安装AIRBFT气动避震性价比低趴姿态之王
发表于 2020-11-14 13:43:23 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Passat B5 installed with airbft pneumatic shock absorber
帕萨特B5是德国大众汽车公司的帕萨特品牌轿车的第五代车型。2000年,上海大众汽车有限公司生产的帕萨特B5正式投放中国市场,在中国上市的帕萨特以德国大众汽车公司的帕萨特轿车为原型,根据中国的法规规定、道路条件和中国用户的审美倾向、使用要求而全新开发的,将原型的B5加长100mm,宽大的体形让帕萨特更适合于国内的商务车市场。成为中型轿车中的高端产品。上海大众还对帕萨特B5进行大的改进,并取了一个别名:领驭。也被人戏称为:帕萨特B5.5。
Passat B5 is the fifth generation model of Passat brand car of German Volkswagen. In 2000, the Passat B5 produced by Shanghai Volkswagen Co., Ltd. was officially put into the Chinese market. Based on the Passat car of German Volkswagen Company, the Passat was newly developed according to Chinese laws and regulations, road conditions, aesthetic inclination and use requirements of Chinese users. The B5 of the prototype was lengthened by 100 mm. The wide shape makes Passat more suitable for China In the business car market. Become the high-end products of medium-sized cars. Shanghai Volkswagen also made a big improvement on Passat B5, and took a nickname: Lingyu. Also known as Passat b5.5.
帕萨特B5改装AIRBFT气动避震后备箱造型说起低趴姿态,将汽车稳稳落地的功臣源于后备箱这小小的气罐。运用物理气压的原理将车身升高降低!来满足改装低趴的乐趣!低趴改装风格已经成为一种时尚,贴地的车身让它比较倾向超跑,酷酷的外表很是抓人眼球,也许是因为它与众不同!今天我们来欣赏大众帕沙特B5气动避震改装案例 低姿态图片鉴赏
Passat B5 refitted airbft pneumatic shock absorber trunk modeling, speaking of low lying posture, the contribution of the car's steady landing is attributed to the small gas tank in the trunk. Use the principle of physical air pressure to raise and lower the body! To meet the fun of refitting low lying! Low lying refit style has become a fashion, the body close to the ground makes it more inclined to run, cool appearance is very eye-catching, perhaps because it is different! Today, let's enjoy the low profile pictures of Volkswagen Pasha B5 pneumatic shock absorber refitting case
