查看: 730|回复: 0
“自信于路,从容于心”斯巴鲁森林人改装气动避震 贴地姿态玩个性
发表于 2020-11-13 15:27:46 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
"Confident in the road, calm in the heart" Subaru foresters refit pneumatic shock absorbers close to the ground posture to play personality
斯巴鲁森林人(Forester)最早于1997年2月份首次面世。森林人汇集了多功能车和客车的特点,如果引用现代的概念,就是一款“交叉”车型。
森林人的底盘借鉴了 1993年的斯巴鲁翼豹,移植到森林人的身上,这款经典的底盘被提高了离地间隙,但是全时四驱和水平对置发动机没有改变。因此森林人不但拥有在恶劣路况条件下的卓越性能以及多用运动车(SUV)所要求的较高的驾驶位置的同时,它还为车手提供令人愉悦的舒适驾驶。
The first appearance of the Subaru Forester was in February 1997. Forest people have collected the characteristics of multi-functional vehicles and buses. If modern concepts are used, it is a "cross" model.
Forestman's chassis is based on the Subaru cheetah of 1993 and transplanted to forestman. The ground clearance of this classic chassis has been increased, but the full-time 4WD and horizontal opposed engine have not changed. Therefore, forestman not only has excellent performance in bad road conditions and the higher driving position required by SUV, but also provides drivers with pleasant and comfortable driving.
有车友会有这样的疑问,我的汽车在改装了气动避震后能让我使劲折腾吗?想跟朋友跑到外地去旅游,改装空气悬挂后能长时间的跑高速吗?听说气动避震改装比一般的避震娇贵些,我还能飙车吗?
Some car friends will have such a question, my car in the modified pneumatic shock absorber can let me struggle hard? Want to travel to other places with friends, after refitting air suspension, can you run high speed for a long time? It's said that pneumatic shock absorbers are more expensive than ordinary shock absorbers. Can I drag?
在回答问题之前我们先了解一下为什么有人说气动避震比一般避震要娇贵些,因为气动避震比原厂避震有更加精密的零件,气动避震器上各带有气囊,利用气囊来减震比一般的减震要舒适,毕竟气体比较柔软嘛,成也萧何败萧何,在利用气囊带来的便利时汽车行驶也要有一些局限性,安装了气动避震的车辆只能在道路良好的路段行驶,因为气动避震经不起太剧烈的颠簸,所以一般只要在柏油马路上正常行驶都没有问题,跑跑高速去外地旅游当然没有问题了!
Before answering the question, let's first understand why some people say that pneumatic shock absorbers are more delicate than ordinary shock absorbers, because pneumatic shock absorbers have more precise parts than original shock absorbers. Pneumatic shock absorbers are equipped with airbags, which are more comfortable than ordinary shock absorbers. After all, the gas is relatively soft, and the success is Xiaohe. When the car is driven by the convenience of the airbag, the car will drive There should also be some limitations. Vehicles equipped with pneumatic shock absorbers can only run on good road sections, because pneumatic shock absorbers can not withstand too severe bumps, so as long as they normally drive on asphalt roads, there is no problem in running high-speed travel to other places!
