查看: 672|回复: 0
起亚K5气动避震改装“衷于领先 革新设计"打造完美新看点
发表于 2020-11-13 15:06:58 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Kia K5 pneumatic shock absorber refitting "for leading innovative design" to create a perfect new point of view
起亚K5是东风悦达起亚旗下的一款中高级轿车,高腰线、强张力的设计让K5更趋动感,体现出来一种朝气与活力,这一款重量级的车型即将在2011年3月份上市。此车外形变动很大,更加时尚前卫,整体风格偏于运动,相当具有竞争力。
Kia K5 is a medium and high-end sedan owned by Dongfeng Yueda Kia. The design of high waistline and strong tension makes K5 more dynamic, reflecting a kind of vigor and vitality. This heavyweight model will be launched in March 2011. The shape of this car changes a lot, more fashionable and avant-garde, the overall style of sports, quite competitive.
说到低姿态改装,最具代表性的肯定是气动避震悬挂,能升能降,在享受低趴美的同时不影响日常使用,可谓一举两得,今天就来介绍一下起亚K5改装AIRBFT气动避震的案例,低趴效果完美展现!
When it comes to low attitude refitting, the most representative is pneumatic shock absorber suspension, which can rise and fall. It can kill two birds with one stone while enjoying the beauty of low lying down without affecting the daily use. Today, let's introduce the case of Kia K5 refitting airbft pneumatic shock absorber, and the low lying effect is perfectly displayed!
气动避震的组成部分为控制系统和气动避震桶身两大类!
Pneumatic shock absorber consists of control system and pneumatic shock absorber barrel body!
Intelligent air replenishment and intelligent adjustment of vehicle level: in fact, the functions of these two functions are the same. For example, the body height is originally horizontal. If a fat man sits in the rear seat, the height of the rear side will be reduced. At this time, the computer will detect the height change at the rear, and respond in less than one second. The two air bags at the back will be inflated to maintain it Body level!
The ignition will automatically rise to the set position height: such a function is no matter what kind of height you park, such as the lowest or the highest, when you stop, get off, and drive again, the system will automatically raise the car to the second gear position, that is, the height of the normal car! This has both advantages and disadvantages. For example, the road condition is very bad. There is no suitable parking space. When parking, stop at the highest position. When you drive again, the system will automatically decrease. If you just stop at a very high rural cement deceleration belt, it is very likely to or directly support the bottom! The advantage is that in a normal parking lot, the parking car will be lowered to the lowest level. When driving again, the train will automatically rise to the normal driving height. Think about how high this force is
One button to the lowest: one button, you can reduce the car to the lowest state! There is a one button down button on the control panel. If you press and hold for 3 seconds, the whole car will be in the lowest state! Why three seconds? Because this is to prevent misoperation. If your car is running, if a child or some special situation accidentally touches the one button lowering button, it is a very terrible thing. In this way, this kind of design can completely avoid this kind of situation. It doesn't matter if you touch all the buttons carelessly, as long as you don't press it for a long time!
