查看: 678|回复: 0
“让世界各地顾客满意”本田奥德赛改装气动避震悬挂打造属于自己的低趴范
发表于 2020-11-13 14:13:56 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
"Satisfy customers all over the world" Honda Odyssey refits pneumatic shock suspension to create its own low lying model
奥德赛是本田公司推出的一款车,于2007年1月在全国上市。配备了卫星导航系统,拥有8英寸的大显示屏和声音引导功能,使用可变气门正时及升程2.4L i-VTEC高性能发动机。
The Odyssey is a car launched by Honda, which was launched nationwide in January 2007. It is equipped with satellite navigation system, 8-inch large display screen and sound guidance function, and uses variable valve timing and lift 2.4L i-vtec high-performance engine.
本田奥德赛商务MPV,不管是家用还是商用都可以,但是总有一些不安分的人拿来改装,改出来的效果还真是不错,我们一起来看看本田奥德赛改装AIRBFT气动避震悬挂后的姿态魅力到底怎样!
Honda Odyssey business MPV, whether it is home or commercial, but there are always some restless people who use to refit, the effect is really good, let's take a look at the Honda Odyssey modified airbft pneumatic shock absorber suspension after the attitude charm in the end!
气动避震的组成部分分为控制系统和气动避震桶身两大类!
From the first time I saw the car refitted with pneumatic shock absorber to now, I am deeply trapped in it, and I have experienced a lot of twists and turns! Also learned a lot about pneumatic shock absorber refitting knowledge!
