查看: 756|回复: 0
彰显青春艳丽奥迪RS4改装空气避震追求时尚个性低趴
发表于 2020-11-13 13:42:37 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Show youth and beauty Audi RS4 refitted air shock absorber pursuit of fashion personality low lying
奥迪RS4采用的FSI汽油直喷技术V8发动机能够输出420马力的功率。
奥迪旗下高性能紧凑型跑车TT的RS性能版——TT RS首度于2009年日内瓦车展亮相,而3年后奥迪似乎觉得该款车还不够给力,于近日推出了更为“凶猛”的版本——TT RS Plus。“更强、更快、更灵活”,这就是奥迪对TT RS Plus所下的评语。和TT RS一样,TT RS Plus带来了Coupe和Roadster(敞篷)两种版本。
Audi RS4 adopts FSI gasoline direct injection technology, V8 engine can output 420 horsepower.
Audi's high-performance high-performance compact sports car TT RS performance version - TT RS debuted at the 2009 Geneva auto show, and Audi seemed awesome after 3 years. Recently, a more ferocious version of TT RS Plus was launched. "Stronger, faster and more flexible" is Audi's comment on TT RS plus. Like TT RS, TT RS plus comes with coupe and roadster.
