查看: 598|回复: 0
LEXUS气动避震悬挂低姿态风格改装让你爱上驾驶
发表于 2020-11-13 13:26:32 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Lexus pneumatic suspension low profile style modification makes you love driving
雷克萨斯(英语:Lexus,日语:レクサス)创立于1983年,是日本丰田集团旗下全球著名豪华汽车品牌。该品牌仅用了十几年的时间,销量在北美地区便超过了奔驰、宝马。1999年起,雷克萨斯品牌连续11年位居美国豪华汽车销量第一的宝座。
2005年,雷克萨斯成功打入日本本土市场,也因此成为在全球均有销售的高级轿车品牌。初时雷克萨斯在美国国内以“热切追求完美”(The Passionate Pursuit of Perfection)作为宣传口号,后来以“追求完美”(The Pursuit of Perfection)作为在全球国家和地区的行销格言,直到2013年,其宣传口号改为Amazing in Motion。
2019年,雷克萨斯在华累计销量突破100万台;  2019全年在华销量200521辆,同比增长25%。
2020年3月,Brand Finance发布了《2020年全球最具价值品牌500强报告》,雷克萨斯排名第200。
In the year 1983, it was the world's largest Australia patriot. It is about 10 years old, and the amount of the article is very beautiful. In 1999, it was the first treasure troop of the first day of the year.
In 2005, it was a success to win the success of the mainland city. In the first time, we have been working on the pursuit of perfection, and the pursuit of perfection.
In the year 2019, the total amount of the total amount of money was exceeded by 1 million; the total amount was 20521 in the total of 2019 in the whole year.
In March 2020, it was announced that the 2020 issue of the 2020 global best weapon was 500 yen.
