查看: 638|回复: 0
双龙主席Korea改装气动避震打造完美新看点
发表于 2020-11-12 15:50:28 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Shuanglong chairman Korea refits pneumatic shock absorbers to create a perfect new point of view
作为第一款庞大旗下国际品牌双龙汽车主导研发的全球顶级豪华轿车,双龙主席W(Chairman W)集结了来自韩方和中方最先进的研发力量和最顶级的造车工艺,它配备了顶级的代表超大型旗舰轿车品味的各项配置,融合了欧式的外观线条,经典的内部装饰,彰显非凡的驾车感受。
  As the first world-class luxury car led by Pangda's international brand Shuanglong automobile, chairman w (Chairman) of Ssangyong Automobile Co., Ltd W) It combines the most advanced R & D forces and the top-level car manufacturing technology from South Korea and China. It is equipped with various top-level configurations representing the taste of super large flagship cars. It combines the appearance lines of European style and the classic interior decoration to highlight the extraordinary driving experience.
