查看: 696|回复: 0
Hyundai grandeur改装气动避震案例享受低姿态乐趣
发表于 2020-11-12 15:23:51 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Hyundai grandeur refitted pneumatic shock absorber case to enjoy low attitude fun
社会的发展,人类的需求,汽车是越来越多,外观的设计也是越来越独特时尚新颖,并且价格也是越来越低,一般价位在10万左右的车子被很多人不放在眼里,即使花几万甚至十几万来改装依然被很多人不屑一顾,今天看看这辆改装气动避震悬挂的低姿态案例,是不是能让您感受到改装的魅力呢?
With the development of society and the demand of human beings, there are more and more cars. The appearance design is more and more unique, fashionable and novel, and the price is also getting lower and lower. Many people don't pay attention to the car with a general price of about 100000. Even if it costs tens of thousands or even hundreds of thousands to refit it, many people still despise it. Today, take a look at the low attitude case of refitting pneumatic shock absorber suspension Can't you feel the charm of refitting?
三段记忆功能:车主可以自行的设置高位,正常,低位三个不同的高度模式,通过按键1 2 3 一键升到或者是降到适合当前路况的高度,高速时可以降到1档低位行驶,降低重心来增强车子的稳定性和降低风阻,还能从一定程度上节省燃油,城市或者是乡村可以升到2档正常的高度来行驶,可以应付大部分路况,如果遇到非常差劲的路况的话可以把车子升到3档,来提高通过性,从最低升到最高大概有12公分左右的行程!3个不同高度的档位可以随时的快速切换
Three segment memory function: the car owner can set three different height modes: high position, normal position and low position by pressing the key 1, 2, 3 One button up or down to the height suitable for the current road conditions, high speed can be reduced to the first gear, low driving, reduce the center of gravity to enhance the stability of the car and reduce the wind resistance, but also to a certain extent save fuel. The city or the countryside can rise to the second gear normal height to drive, can deal with most of the road conditions, if encounter very bad road conditions, you can raise the car to 3 Gear, to improve the trafficability, from the lowest to the highest about 12 cm journey! Three gears with different heights can be quickly switched at any time
There are three main choices in refitting shock absorbers, which are competitive short spring, suit and twisted teeth. These functions are different and the prices are quite different. The most important thing is to choose the best one for yourself. So what is the right shock absorber for you? After replacing and refitting the shock absorber, the first thing to bear is the loss of comfort. Therefore, if you still pursue the comfort of the vehicle, then I suggest you don't replace it here. If there is no problem with a little loss, the replacement package can not only improve the handling of the vehicle, but also avoid losing too much comfort. Because the appearance of the suit is to improve the handling performance of the vehicle on the large structure of the original shock absorber. However, there are also many deficiencies in shock absorbers. First, the price is a little expensive. Second, damping and height can not be adjusted. Third, at present, the main brands of shock absorbers are still concentrated in European cars. Japanese car suits are not popular. However, for many senior players, the shock suit has not been able to meet their needs, so the first choice for them is to hang teeth. Actually, the word "twisted teeth" comes from Hong Kong, China. Its real full name is height. Adjustable. Damper, which means the number of damping segments of adjustable shock absorbers and body height. Seeing this name, I don't think I need to introduce its functions too much. It's all reflected in the name. However, Xiaobian has to add that although the ideal body height and handling performance can be obtained after the replacement of the hinge suspension, it is based on the loss of 60% of the comfort, so it is best to make psychological preparation before replacement
