查看: 618|回复: 0
“移动的商务舱”奔驰V260 AIRBFT气动避震瞬间改善舒适性能
发表于 2020-11-12 13:56:11 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
"Mobile business class" Mercedes Benz V260 airbft aerodynamic shock absorbers improve comfort instantly
梅赛德斯-奔驰V级 MPV的独特设计令人过目不忘,惬意宽阔的空间里,空间内拥有豪华真皮电动单人座椅,配备扶手、豪华头枕、腿托,座椅加热、座椅通风及按摩功能,处处彰显人性化设计。全新配备米色与黑色双色内饰,多种风格可供选择,奢华更进一步,铭刻着值得被时间细细诉说的故事。对于这款车性价比很高,豪华型不言而喻,奔驰主要高端市场,V级MPV拥有宽敞灵活的内部空间应用方案,像把起居室搬到公路上,为驾乘者带来难以言喻的享受和体验。
The unique design of Mercedes Benz V-Class MPV is unforgettable. In the comfortable and spacious space, there are luxury leather electric single seat, armrest, luxury headrest, leg support, seat heating, seat ventilation and massage functions, which highlight the humanized design everywhere. New beige and black interior, a variety of styles to choose from, further luxury, engraved worthy of time to tell the story. For this car, it is self-evident that the luxury model is of high cost performance. Mercedes Benz is mainly in the high-end market. The V-Class MPV has a spacious and flexible internal space application scheme, such as moving the living room to the road, which brings unspeakable enjoyment and experience for drivers and passengers.
奔驰V260改装空气悬挂的效果案例,经由设计师的精心设计,唯一的缺点就是悬挂效果不尽人意,舒适性的提升就差一套AIRBFT空气悬挂。今天我们来分享奔驰V260改装AIRBFT空气悬挂的舒适性体验!
Mercedes Benz V260 modified air suspension case, through the designer's careful design, the only drawback is that the suspension effect is not satisfactory, and the improvement of comfort is inferior to a set of airbft air suspension. Today, let's share the comfort experience of air suspension of Mercedes Benz V260 refitting airbft!
