查看: 648|回复: 0
姿态党 大众桑旅气动避震改装充满动感魅力
发表于 2020-11-11 16:28:18 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Attitude: the aerodynamic shock absorber refitting of the party Volkswagen sanglv is full of dynamic charm
桑旅:也就是桑塔纳旅行车,通常人们都叫它“桑旅”。
它的原型车是德国大众公司的帕萨特b2。b2在德国本土只生产了13万辆,而作为第一款合资生产的轿车,桑塔纳在中国已经生产了19年,累计产量200多万台。19年间上海大众对桑塔纳不断进行改进,直到今天桑塔纳还在不停的驶下生产线。
旅行车在内装设计上,我们不能对八十年代的老车型提过高的要求。在驾驶席上,四幅方向盘样式陈旧,车内找不到什么“中央控制板”的概念,所有的控制键都集中在仪表台上,伸手去够还要先绕开方向盘这一关。空调控制依然是早被淘汰的拉杆式。
桑塔纳在各个方面都基本沿袭了八十年代进入中国时的风格。上海大众对它进行的不断改进也保证了它19年间的经久不衰。但不能否认的一点是,无论在内外设计还是在技术水平上,桑塔纳都和新生车型不在同一个技术层面上。在与同价位车型的竞争中,它唯一的优势只能体现在车内空间和维修保养方面。随着时间的进一步增长,桑塔纳和现代轿车之间的差距会越来越大,退出历史舞台的日子也不会太远了。
Sanglv: also known as Santana station wagon, it is usually called "sanglv".
Its prototype is a Volkswagen Passat B2. B2 has only produced 130000 cars in Germany. As the first joint venture car, Santana has produced more than 2 million cars in China for 19 years. In the past 19 years, Shanghai Volkswagen has continuously improved Santana, and even today, Santana still keeps driving off the production line.
In the interior design of station wagon, we can't set too high a demand on the old models of 1980s. In the driver's seat, the style of the four steering wheels is old, and the concept of "central control panel" is not found in the car. All the control keys are concentrated on the instrument panel. If you reach for them, you have to bypass the steering wheel first. Air conditioning control is still a pull rod type which has been eliminated for a long time.
Santana basically followed the style of China in 1980s. The continuous improvement made by Shanghai Volkswagen has also ensured its long-term survival for 19 years. However, it can not be denied that Santana is not at the same technical level as the new models in terms of internal and external design and technical level. In the competition with the same price model, its only advantage can only be reflected in the car interior space and maintenance. With the further growth of time, the gap between Santana and modern cars will become larger and larger, and the day of withdrawing from the historical stage will not be too far away.
HellaFlush是一种风格,或是一种文化,又或是一种态度。不管别人把它看是什么,HellaFlush 的中心思想就不会变: 喜欢,或不喜欢,一切与HellaFlush无关,无论到了何年何月,我们就齐刷刷的趴着,趴着,趴着!
Hella flush is a style, or a culture, or an attitude. No matter what others think of it, hellaflush's central idea will not change: like, or not like, everything has nothing to do with hellaflush, no matter what year or month, we will be lying down, lying down, lying down!
2. 车身高度一定要尽量低,从车的侧面看绝对不能在轮胎和叶子板之间有空隙,如今HellaFlush已经成为了一个国际化的改装车的外观潮流,越来越流行,越来越被大众所接受,无论类型车种贫富贵贱,HellaFlush已经趋向为一种品味的认证。所以,一起加入这个运动吧!
2. The height of the body must be as low as possible. From the side of the car, there must be no gap between the tire and the vane. Now hellaflush has become an international appearance trend of refitted cars. It is more and more popular and is more and more accepted by the public. Regardless of the type of car, hellaflush has become a taste certification. So, join the movement!
