查看: 514|回复: 0
低趴灵魂制造者大众尚酷改装气动避震属于自己的特色
发表于 2020-11-10 16:51:17 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Low lying soul maker Volkswagen Shangku refitting pneumatic shock absorber is its own characteristics
尚酷,英文名称Scirocco,拥有前卫动感的设计,被誉为“大众汽车有史以来最具动感”的双门跑车,是一辆全天候高性能跑车,2010年4月9日于上海上市.
尚酷驱动方式为前轮驱动,制动方式为通风盘式,引擎为L型4缸2.0升燃油直喷式,提供“运动版”和“豪华版”两个车型供消费者选择。
Shangku, English name Scirocco, with avant-garde dynamic design, known as "Volkswagen's most dynamic" two door sports car, is an all-weather high-performance sports car, on April 9, 2010 in Shanghai
Shangku's driving mode is front wheel drive, the braking mode is ventilated disc, the engine is L-type, 4-cylinder, 2.0-liter fuel injection type, and two models of "sports version" and "luxury version" are provided for consumers to choose.
改装是每一个玩车人都必经一个阶段,原厂件虽然耐用但是美观程度却不行,所以所外观姿态比较讲究的玩家就会对车子进行改装,就出现了很多的改装风格,比如:VIP、Hellaflush等。今天我们来欣赏大众尚酷改装AIRBFT气动避震悬挂的低趴风格,只改了减震效果不是很好,期待更换轮毂数据的完美姿态!
Refitting is a stage that every player has to go through. Although the original parts are durable, they are not good-looking. Therefore, players who pay more attention to the appearance and posture will refit the car, resulting in many modification styles, such as VIP, hellaflush, etc. Today, let's enjoy the low lying style of Volkswagen Shangku refitting airbft pneumatic suspension, only changing the shock absorption effect is not very good, looking forward to the perfect posture of changing the wheel hub data!
