查看: 584|回复: 0
Ford福克斯改装气动避震空气悬挂 彻底爱上低姿态
发表于 2020-11-10 15:56:47 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Ford fox refits pneumatic shock absorber air suspension to fall in love with low attitude
汽车升降底盘的改装,也就是常说的气动避震改装,改装气动避震后的车辆可以随心所欲调节底盘高度,从容应对各种驾驶需求。在坎坷的道路上行驶时,不少车主总是害怕爱车底盘被磕碰,在长途高速驾驶的时候,很多车主也会因为自己爱车的车身较轻觉得驾驶起来有点“飘”,一成不变的底盘高度似乎很难适应各种不同的路况。
The refitting of automobile lifting chassis is often called pneumatic shock absorber modification. After refitting the pneumatic shock absorber, the vehicle can adjust the chassis height at will to meet various driving demands calmly. When driving on rough roads, many car owners are always afraid that their car chassis will be bumped. When driving on long-distance and high-speed roads, many owners will feel that their car is a little "floating" because of its light body. It seems that the constant chassis height is difficult to adapt to various road conditions.
如果说低趴风格改装已成风,大家对此已经见怪不怪的话,那么相信接下来的一定会非常引人眼球,继气动悬挂成为大家改装的主流之后,极端的“恐高症”患者们都开始往更加极端的方式去改装,低趴的姿态与硕大尺寸的轮毂完全不能满足他们的胃口,所以视觉效果十分夸张的宽体车身就成为了他们的改装方向。
If we say that low lying style refitting has become a fashion, and we are not surprised by this, we believe that the next step will be very eye-catching. After pneumatic suspension has become the mainstream of everyone's refitting, the extreme "acrophobia" patients are beginning to go to a more extreme way to refit. The posture of low lying down and the huge size of wheel hub can not satisfy their appetite, so vision is very important The effect is very exaggerated wide body has become their refitting direction.
Let's break down the word hellaflush = Hella flush, that is, there are two parts, one is Hella, the other is flush. Hella is the abbreviation of "hell of", which means special, extraordinary, absolute and super; flush means flush. Therefore, two points should be understood here: 1. The formation of hellaflush must first satisfy the requirements of flush, that is, flat wheel tires, and then be qualified to make efforts from flush to hellaflush; 2. The body height must be as low as possible, and there must be no gap between the tire and the leaf plate from the side of the car.
