查看: 738|回复: 0
宝马E90改装气动避震 演绎低趴姿态HellaFlush风格
发表于 2020-11-10 14:53:39 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
宝马3系E90改装气动避震 演绎低趴姿态HellaFlush风格
BMW E90 modified pneumatic shock absorber for low lying posture Hella flush style
宝马E90是宝马第五代3系,这代3系也是车迷们津津乐道的一代3系
E90是底盘代号,第五代宝马3系的价格贵,空间小,故障率高,但是这可以说是车迷们最喜欢的一代宝马3系车型了,因为这代车型的操控是非常好的。
The BMW E90 is the fifth generation 3 series of BMW. This generation of 3 series is also a generation 3 series that fans like to talk about
E90 is the chassis code. The price of the fifth generation BMW 3 series is expensive, the space is small, and the failure rate is high. However, it can be said that this generation of BMW 3 series model is the favorite of the fans, because the handling of this generation of models is very good.
气动避震的改装都想用带有记忆功能的控制系统,但是气压记忆稳定性不好,会受到温度和车身重量的影响。高度记忆就是最理想的,不过高度尺的安装固定让很多店家感到苦恼,总是不能找到最好的安装位!今天我们来看看宝马E90安装气动避震悬挂高度尺安装位的固定!
Pneumatic shock absorbers want to use the control system with memory function, but the stability of air pressure memory is not good, which will be affected by temperature and body weight. Height memory is the most ideal, but the installation and fixation of the height gauge makes many stores feel distressed, and they can't always find the best installation position! Today, let's take a look at the fixing of mounting position of BMW E90 pneumatic shock absorber suspension height gauge!
