查看: 580|回复: 0
“简洁+大气”奔驰威霆 AIRBFT空气悬挂施工
发表于 2020-11-7 14:55:59 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Air suspension construction of "simplicity + atmosphere" Benz Weiting airbft
奔驰威霆是德国奔驰推出的一款MPV,于2010年推出,定位“专业级MPV”梅赛德斯-奔驰威霆(Vito)  ,是福建奔驰旗下的明星产品。轴距长3430mm,车内空间宽大,7-9座设置满足团体出行需求。
福建奔驰威霆采用了“简洁+大气”的设计风格。全新鹰式造型头灯一改过去水滴头灯形状,尽显大气和犀利。而前大灯和尾灯之间的两条独具匠心的设计线条,让车身动感十足。全新刀锋造型的两片式进气格栅造型给车辆赋予了一份干练和健硕的气质。
凭借“尊而不贵”的高性价比、卓越的性能、稳健大气的外观、优异的安全可靠性,威霆自上市至今受到众多行业用户的青睐,也多次获得行业机构的肯定。
Mercedes Benz Vito is a MPV launched by German Benz in 2010, positioning "professional MPV" Mercedes Benz Vito. It is a star product of Fujian Benz. The wheelbase is 3430mm long and the interior space is wide. 7-9 seats are set to meet the needs of group travel.
Fujian Benz Weiting adopts the design style of "simplicity + atmosphere". The new Eagle shaped headlamp changes the shape of the water drop headlamp, showing the atmosphere and sharpness. And the two unique design lines between the front headlight and the tail lamp make the body dynamic. The new blade shape of the two-piece air intake grille gives the vehicle a capable and strong temperament.
With "respect but not expensive" high cost performance, excellent performance, stable and atmospheric appearance, excellent safety and reliability, Weiting has been favored by many industry users since its listing, and has been affirmed by industry organizations for many times.
