查看: 638|回复: 0
奔驰GLC改装案例 气动避震悬挂低趴改装的魅力
发表于 2020-11-7 14:31:18 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Mercedes Benz GLC refitting case the charm of pneumatic shock absorber suspension low lying refitting
奔驰GLC是奔驰推出的首款全新跨界车型,2015款发布。奔驰GLC实质上可以看做是GLK的轿跑版,而之所以奔驰GLC要到2016年才会问世。
奔驰正在计划主要依靠其SUV与跨界车,推出的首款全新跨界车型是2015款奔驰GLC。
Mercedes Benz GLC is the first new crossover model launched by Mercedes Benz, with 2015 model released. Mercedes Benz GLC can be regarded as the car running version of GLK in essence, and the reason why Benz GLC will not come out until 2016.
Mercedes Benz is planning to rely mainly on its SUVs and crossover vehicles, and the first new crossover model launched is the 2015 Mercedes Benz GLC.
奔驰GLC改装气动避震改装真的舒适吗?很多车友改装过气动避震之后的普遍反映就是车子悬挂过硬!开起来毫无舒适性可言!其实这跟避震的调节有着很大的关系!
因为是把弹簧替换成气囊 而气囊的灵敏度要比弹簧高 所以可以有效的过滤掉路面的颠簸。但是绞牙避震定制皮囊之后,需要避震桶的高度和皮囊气实量的大小和避震阻尼一个完美的配比才能达到很好的舒适度,需要很好的测量和路试!
Is it really comfortable to refit Mercedes Benz GLC with pneumatic shock absorber? After many riders refitted the pneumatic shock absorber, the common reflection is that the car suspension is excellent! No comfort to drive! In fact, this has a lot to do with the adjustment of shock absorbers!
Because the spring is replaced by an air bag, and the sensitivity of the air bag is higher than that of the spring, it can effectively filter out the bumps on the road. However, after the customized leather bag is customized, the height of the shock bucket and the air volume of the leather bag and the shock damping are required to achieve a perfect ratio to achieve good comfort, which requires good measurement and road test!
