查看: 560|回复: 0
三厢福克斯AIRBFT气动避震改装低趴姿态
发表于 2020-11-4 16:44:15 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Three chamber fox airbft pneumatic shock absorber refitted low prone attitude
全新福克斯2020款是长安福特公司于2019年7月11日正式上市,售价9.98万元-15.08万元。作为年度改款车型,新一代福克斯2020款与旧款相比售价一致,但全系车型符合国六排放标准,而且还在两款中配车型上换装了ST-Line车型运动套件,配置也进行了提升。
The new Fox 2020 model was officially launched by Changan Ford company on July 11, 2019, with a price of RMB 99800-150800. As an annual change model, the price of the new generation fox 2020 model is the same as that of the old model, but the whole series of models meet the national VI emission standard, and the st line sports kit is replaced on the two Chinese models, and the configuration is also improved.
经典福克斯改装气动避震低趴案例的相关改装信息, 福克斯气动避震改装采用的 AIRBFT空气悬挂套件,稳定的性能,卓越的品质,四轮独立升降和三段记忆功能,是目前世界上最顶尖的一套空气悬挂产品,也是每个气动避震爱好者的梦想,再加上包围和前铲的贴地效果,效果更加的完美。
This paper introduces the modification information of the classic fox pneumatic shock absorber low lying case Airbft air suspension kit, with stable performance, excellent quality, four-wheel independent lifting and three-stage memory function, is currently the world's top air suspension product, and also the dream of every pneumatic shock absorber enthusiast. In addition, the effect of surrounding and front shovel on the ground is more perfect.
汽车避震是由弹簧和减震器共同组成的。
The car shock absorber is composed of spring and shock absorber.
Spring is used to eliminate vibration when driving uneven road. Spring can eliminate vibration. What does the shock absorber do?
In fact, shock absorber is used to make the spring rebound field after shock absorption and reduce the energy of road impact.
If you drive a car with a broken damper, you can experience the car's bouncing through every hole and the afterwave after the ups and downs, which are used to suppress the bounce.
Without shock absorber, spring rebound will not be controlled. When the car encounters rough road, it will produce serious bounce. When the car passes the bend, it will also cause the loss of traction and track of the tire due to the vibration of the spring.
When we mention the shock absorber, we have to mention another term "damping". Damping is when we compress or stretch the shock absorber at a fixed speed, and the resistance it produces, so the resistance of the shock absorber can be divided into compression and rebound. The harder shock absorber will produce more resistance, and the rebound resistance will be greater naturally. It can resist the force of the spring compression before pressing the tire back to the ground, slow down the impact of rebound and keep the vehicle stable.
When we are bending in and out of the bend, the weight transfer speed of the vehicle will affect the balance of operation, which will continue until the completion of the weight transfer. The weight transfer speed of the body is controlled by the shock absorber. The harder the shock absorber, the faster the weight transfer speed is, the faster the transfer speed will drive the steering response.
