查看: 626|回复: 0
颜值与性能的结合宝马E93改装气动避震悬挂圆你心中低趴梦想
发表于 2020-11-4 15:57:35 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Combination of appearance and performance BMW E93 modified pneumatic shock proof suspension circle, your heart lies down on your dream
这几年可以说是气动避震改装最火热的,各种品牌的气动悬挂套件层出不穷,让玩家也是选择困难,今天这辆宝马E93选用的是性价比最强,稳定最好的AIRBFT气动悬挂,看看经典的宝马E93改装AIRBFT的精彩魅力
In recent years, it can be said that pneumatic shock absorbers are the most popular. Various brands of pneumatic suspension kits emerge in endlessly, which makes it difficult for players to choose. Today, this BMW E93 selects the airbft pneumatic suspension with the strongest cost performance and the best stability. Take a look at the wonderful charm of the classic BMW E93 refitting airbft
喜欢玩改装避震系统的发烧友,空气避震是话题里面最贵的一款。
听起来非常方便,气动避震到底是什么原理呢?
